Parking brake light in dash comes on...
Old Jan 14, 2008 | 11:31 PM
WAFFLES's Avatar
Default Parking brake light in dash comes on...
Today on two seperate occasions I had the brake light in the dash light up on me, directly after WOT acceleration. The light went off after I came to a complete stop. I'm wondering if this is a common issue with this car. I just serviced the car over the last weekend, and I inspected all brake lines, brakes, tires etc. Any TSBs on this? I tried searching the forum and found nothing. Thanks.
Old Jan 14, 2008 | 11:34 PM
SquallLHeart's Avatar
you check your brake pads?
Old Jan 15, 2008 | 02:15 AM
WAFFLES's Avatar
Yeah brake pads still had a good deal of friction pad on them. Left side had about 1/8" and right side had about 3/16".
Old Jan 15, 2008 | 02:58 AM
JSosa's Avatar
check your brake fluid, thats usually the sensor in the reservoir letting you know that it needs a refill.
Old Jan 15, 2008 | 03:00 AM
FuzzMaster's Avatar
its brake fluid. same thing happened to my moms corolla
Old Jan 15, 2008 | 04:24 AM
the brake fluid is low because the pads are going...
1/8"?!?! yeah man.... you're due to change pads.
Old Jan 15, 2008 | 06:26 AM
Sasnuke's Avatar
Time for some front pads, thats why the fluid is low. Look in the reservoir you will probably see the fluid close to the "MIN" level. When you install the new pads & push the caliper piston back in the fluid "should" return to the "MAX" level.
Old Jan 15, 2008 | 06:35 AM
yea... if you refill your fluid blindly.... when it comes time to change your pads...
(which technically should be now)... that reservoir is gonna overflow and uhh... brake fluid isn't good for paint and other things last time i heard..
Old Jan 15, 2008 | 04:30 PM
SLIM187's Avatar
sounds to me like the brake resevior is getting low on fluid...but also to if it only at wide open throttle it could be the alternator not charging causing the light to come on..it on the sme circuit as the brake light...but double check the brake fluid first...
Old Jan 16, 2008 | 12:03 AM
WAFFLES's Avatar
Sorry guys, but the brake fluid is fine. It's just under the max marker.
Also, wear limit on the pads is .04", which is quite less than .125".
Thanks for the suggestions, including that on the altenator. I will run a check on it at work tomorrow.
Old Jan 16, 2008 | 01:30 PM
Improbcat's Avatar
If it is the parking brake light, the WOT could be causing the g-force to pull back on the parking brake assembly just enough to make it think the parking brake is on, and trip the light. Then when you brake and come to a halt everything shifts again and the light goes out.
If that is the case you can check the adjustment of the switch for the parking brake, and/or loosen the parking brake cables slightly.
Old Jan 16, 2008 | 03:46 PM
WAFFLES's Avatar
I was kindof thinking that. When the light came on, I tried playing with the handbrake and tried tapping the brakes. The light would not go out until I came to a complete dead stop. I have not had a problem since the other day though...
Old Jan 20, 2008 | 01:52 PM
nautyblu06's Avatar
Just to add to your comments, i have a tC and I just ran into the same problem. But my light doesn't stay on as long as yours. It only stays on at WOT and then goes out when i let go of the accelerator.......
Old Jan 22, 2008 | 01:42 PM
nautyblu06's Avatar
After work yesterday, I checked out my brake fluid level and it was just above min. While driving, I kept flooring the gas to see if the brake light would come on, and it did at WOT. It only comes on when the car accelerates fast. This morning i went to Autozone and bought some brake fluid. Filled it up to just about max and took the car for a test drive. No more brake light. SLIM187, you were right for my situation on the brake fluid reservoir being low. Thanks.......
Old Jan 22, 2008 | 04:44 PM
..... did you bother to even check your brake pads first?
you need to know why your brake reservoir level was low you know.
xBSciontist
Jun 18, 2019 03:06 PM
mischman
Jan 14, 2015 06:07 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
bruceb25
Nov 23, 2014 04:52 AM
randode
44
Jun 29, 2004 04:19 PM
