For all of you that are going to do Air Travel..
Old Jan 17, 2008 | 04:30 PM
rj's Avatar
rj
Default For all of you that are going to do Air Travel..
Scott.. Garage1217... Brent etc..
Hope you saw these new rules for batteries and air travel for 2008...
Little email sent out by my work.
here is the web link
http://www.tsa.gov/travelers/airtrav...batteries.shtm
Safe Travel with Batteries and Devices
Air Travel
Travel Alert!: Effective January 1, 2008, the Department of Transportation will prohibit loose lithium batteries in checked baggage.
Photo of laptop and cell phone
Effective January 1, 2008, the Department of Transportation (DOT) through the Pipeline and Hazardous Materials Safety Administration (PHMSA) will no longer allow loose lithium batteries in checked baggage.
Learn more at http://safetravel.dot.gov/whats_new_batteries.html.
Some Tips for Safe Travel With Batteries
* Keep batteries and equipment with you, or in carry-on baggage - not in your checked baggage! In the cabin, flight crew can better monitor conditions, and have access to the batteries or device if a fire does occur.
* Buy batteries from reputable sources and only use batteries approved for your device – avoid counterfeits! A counterfeit battery is more likely to cause a fire in your equipment – costing you more in the long run, and compromising safety.
* Look for the mark of an independent testing or standards organization, such as Underwriters Laboratories (UL) or International Electrotechnical Commission (IEC).
* Do not carry recalled or damaged batteries on aircraft. Check battery recall information at the manufacturer's website, or at the Consumer Product Safety Commission.
* Only charge batteries which you are sure are rechargeable! Non-rechargeable batteries are not designed for recharging, and become hazardous if placed in a battery charger. A non-rechargeable battery placed in a charger may overheat or cause damage later.
* Only use a charger compatible with your rechargeable battery – don’t mix and match!
* If original packaging is not available for spare batteries, effectively insulate battery terminals by isolating the batteries from contact with other batteries and metal. Do not permit a loose battery to come in contact with metal objects, such as coins, keys, or jewelry.
* Place each battery in its own protective case, plastic bag, or package, or place tape across the battery's contacts to isolate terminals. Isolating terminals prevents short-circuiting.
* Take steps to prevent crushing, puncturing, or putting a high degree of pressure on the battery, as this can cause an internal short-circuit, resulting in overheating.
* If you must carry a battery-powered device in any baggage, package it to prevent inadvertent activation. For instance, you should pack a cordless power tool in a protective case, with a trigger lock engaged. If there is an on-off switch or a safety switch, tape it in the "off" position.
Lithium Batteries: Safety and Security
Image of a lithium ion battery.Lithium-ion batteries, often found in laptop computers, differ from primary lithium batteries, which are often used in cameras. Some newer AA-size batteries are also primary lithium.
While there is no explosion hazard associated with either kind of battery, the Federal Aviation Administration has studied fire hazards associated with both primary and lithium-ion cells, and their extensive research is publicly available. As a result of this research, the FAA no longer allows large, palletized shipments of these batteries to be transported as cargo on passenger aircraft.
The research also shows that an explosion will not result from shorting or damaging either lithium-ion or primary lithium batteries. Both are, however, extremely flammable. Primary lithium batteries cannot be extinguished with firefighting agents normally carried on aircraft, whereas lithium-ion batteries are easily extinguished by most common extinguishing agents, including those carried on board commercial aircraft.
TSA has and will continue to work closely with the FAA on potential aviation safety and security issues, and TSA security officers are thoroughly and continually trained to find explosive threats. TSA does not have plans to change security regulations for electronic devices powered by lithium batteries.
Old Jan 17, 2008 | 04:47 PM
MTcX's Avatar
Scionetics
wow, thank you very much for this information RJ. I will be traveling again in March so this is good to know. I will be sending out this information to my entire company as well.
Old Jan 17, 2008 | 04:55 PM
dudehitt's Avatar
thanks rj.
Old Jan 17, 2008 | 08:51 PM
Soupy_TC's Avatar
Team No Limitz
Coming Soon... All the batteries that I take outta peoples luggage for sale.... CHEAP!! LOL
Old Jan 18, 2008 | 02:31 PM
Garage1217's Avatar
Thanks man. yeah I saw that. Guess they had a few blow up or start smoking in the cargo hold. I always carry my extra laptop battery with me in my carry on so all good.
Old Jan 18, 2008 | 03:06 PM
dudehitt's Avatar
it's only Lithium, right? I guess with the number of people's luggage you get to rummage through you'll get some, but I wouldn't think that many people would put their spares in their suitcases.
Old Jan 18, 2008 | 03:15 PM
Soupy_TC's Avatar
Team No Limitz
yeah only the Lithium ones... just use the original packaging or a baggy and you wont have to worry about it... we haven't started doing this yet... they told us the the news needs to inform people before it goes into effect...
Old Jan 18, 2008 | 08:46 PM
mywifesbox's Avatar
I'm fine with taking my batteries, but don't cavity search me!
Old Jan 18, 2008 | 08:50 PM
mywifesbox's Avatar
BTW, good info RJ. I traveled last week but heard nothing about it or maybe I was too busy checking out the chicks to not see posted signs.
Old Jan 18, 2008 | 10:26 PM
Soupy_TC's Avatar
Team No Limitz
Sorry I DON'T get paid enough to do that!!!!
elwaylite
9
May 15, 2020 07:27 PM
Jumphiggggg
Scion tC 1G ICE & Interior
Jul 15, 2015 02:29 AM
StxArOne
Jul 13, 2015 06:25 PM
hampton1100
May 28, 2015 07:32 AM
carid
Mar 30, 2015 07:08 AM
