2004-2006.5 [NCP61]
A/C,Heater Control
Old Jan 19, 2008 | 03:27 AM
Charliec's Avatar
Default A/C,Heater Control
This is my first post. I have a 2006 XA that I bought new. The heater control does not go all the way to heat or to full A/C. The **** springs back to 3/4 heat or 3/4 A/C. The dealer said that this is normal. I don't think it is. Has anyone run across this too? Is there a fix? Thanks for any help on this.
Old Jan 19, 2008 | 11:33 AM
dand's Avatar
Mine often doesn't go all the way up to max heat, springing back a notch or two like you described. But it doesn't seem like there's any difference in the heat between the *** actually being on max and being a couple notches back.
Old Jan 20, 2008 | 02:38 AM
Charliec's Avatar
Thanks Dan.
Old Jan 26, 2008 | 02:03 PM
spike443's Avatar
Yeah same with my wife's xA. Weird, but normal, I think.
Old Jan 26, 2008 | 03:19 PM
jct's Avatar
jct
its normal my car does it too, i'm glad on those hot days i can crank all the way over to cool to help cool me off...
Old Jan 28, 2008 | 01:17 PM
carlitoselcool1's Avatar
well you know that today in the morning was cold down here in miami and i had to put the heater for the first time and it is true that the thing does not goes all the way to the maximum heat you push it and it keeps coming back so probably its a factory problem
Old Jan 28, 2008 | 11:31 PM
cobb's Avatar
Same here. Its just moving a cable when you twist the **** to move a flap in the air box to allow air to blow through the heater core. If it does not close tight, some unheated air could leak through.
I wouldnt worry, I find the hvac equally poor in heating as it is in cooling.
BlingSlade
Oct 19, 2016 12:39 AM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Jus2tastee
Oct 1, 2015 08:57 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
BlingSlade
Sep 5, 2015 08:52 AM
