synapse wastegate question
Old Jan 25, 2008 | 10:39 PM
KrazyAzianTC's Avatar
Default synapse wastegate question
i have the dezod s1 turbo kit with the synapse wastegate. i bought the kit used off of someone here on SL but he did not include the instructions for the wastegate. i was wondering if anyone on the forum has used this wastegate and would be able too provide me the install manual or guide me through the install. thanks
nate
Old Jan 26, 2008 | 01:16 AM
aen's Avatar
aen
that is one nice ___ wastegate, sorry but i don't know how to use it.
Old Jan 26, 2008 | 02:50 AM
deathbyc4's Avatar
depending on the high pressure side depends on where you need to plug in the vacuum line. if the bottom of the wastegate ( the one with the valve visible) is the high pressure side, then the vacuum line goes to the port cloest to the valve ( on the base of the shiny part close to the valve part). otherwise, you use the top port.
http://videos.streetfire.net/video/5...86003c41aa.htm
Old Jan 26, 2008 | 03:20 AM
im more confused on where too connect my vaccum lines for the wastegate if that makes any sense at all
Old Jan 26, 2008 | 09:18 AM
bumnp...anyone?
Old Jan 26, 2008 | 12:45 PM
paul_dezod's Avatar
Scionetics
KAD
Well the WG has 4 ports and you can use 1 for 5PSI, one for 7 PSI, one for 10 or something like that.
Go to here:
http://www.synapseengineering.com/
Hit archives and then DL the manual for the WG
Old Jan 26, 2008 | 09:09 PM
thanks for the replies guys. now i ran into anohter problem . i am using the the blitz dual-sbc spec s boost controller. it is telling me too connect the sloenoid fromt he controoler too the top of the wastegate and then the bottom port of the wastegate too the turbo.
now the wastegate tells me too connect port C&D too the boost source and nothing too the trubo im really confused.
some one please help me
thanks
nate
Old Jan 26, 2008 | 09:35 PM
Ace83's Avatar
Ronin Scion
nice wastegate!
Old Jan 26, 2008 | 10:08 PM
thanks just wish i knew wat i was doing with it haha
Old Jan 27, 2008 | 04:00 PM
bruceg's Avatar
lol good luck with all that man...
Maybe just install it without the boost controller....if you didn't mind that is.
Old Jan 28, 2008 | 12:44 PM
paul_dezod's Avatar
Scionetics
KAD
For now, just use the WG, as you can regulate the boost with just the 4 vac ports from: 5.2, 5.6, 7.7, 9.2, 10.5 and 13 .8 PSI!
Old Jan 28, 2008 | 05:52 PM
OuterHeaven's Avatar
Try this link out http://synapseengineering.com/smf/index.php?topic=5.0
Old Jan 30, 2008 | 08:01 AM
heres anohter noob question and hopefully somone can answer it . my boost guage tells me too connect the in side too a pressure port from before the throttle body. would that be the same as connecting it too the vacuum source?
Old Jan 30, 2008 | 03:05 PM
redrumtc's Avatar
Strictly Scionized
do u have the synapse bov ?
Old Jan 30, 2008 | 03:20 PM
Resu's Avatar
I'm sorry I have no mercy today..but did you read the very first thing he said?
Old Jan 30, 2008 | 03:26 PM
redrumtc's Avatar
Strictly Scionized
I have no clue what comes with that kit . it came with a synapse wast right? Then it mit have came with the bov I want to now what it sounds like on a tc. is that a good answer for u resu.
Old Jan 30, 2008 | 07:49 PM
paul_dezod's Avatar
Scionetics
KAD
The kit came with a traditional HKS SSQV, and a Synapse gate, per the original owner's request.
Yes, all from virtually the same pressure source on the IM
Old Jan 30, 2008 | 10:17 PM
thanks paul and everyone else for helping. hopefully will get it tuned this week
thanks
nate
Old Jan 31, 2008 | 11:07 PM
Resu's Avatar
It's okay redrum, np.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
xBassist
9
Jan 21, 2004 07:34 PM
