Blazer foglights, Lowes Rocker Switch + Factory Scion Relay?
I looked thru previous threads with no answer
*Is there any way to hook up the Blazer Foglights (from Walmart or where ever) to the factory harness under the head lights (splicing?) and then install the Scion fog light Relay,
and then
use the rocker switch from Lowes to make it all work?.
If so can any write up a how to, ie where to splice, tap or solder (the cleaner looking the better)
thanks
and then
thanks
ive got a set and this is how i wired them up:
both grounds wired together and then to the frame, both + to a rocker switch and then to the parking light in the front drivers turn signal. just test with a voltage meter to find the right wire thats hot when you turn on your parking lights.
so this way i gut leave the rocker switck on and when i turn on the parking lights and or head lights the fog/driving lights come on and if i want them off for some reason i just hit the rocker swtich
minter66
Dec 15, 2014 01:45 PM
randode
44
Jun 29, 2004 04:19 PM
