19' rsl with 215 35 19
Old Feb 8, 2008 | 08:28 PM
devskinner's Avatar
Default 19' rsl with 215 35 19
i need to know if anyone has this setup .. i just wanted to know if it wil fit my rs2.0 .. if anyone has ideas for a better fit for this set up .. hook a brother up
Old Feb 8, 2008 | 09:13 PM
burstaneurysm's Avatar
I wanna say you need 30 series tires to maintain the proper wheel ratio... otherwise your speedo will be off a bit.
Old Feb 9, 2008 | 12:13 AM
Ekolu2004's Avatar
how wide are the wheels if it's a 7.5 then 215/35's would work real nice, i had some 19" racing heart CR's before they were a pain in the A**! also are you dropped if it's a mild drop (2") you should be ok... with a little rub here and there. but when you have to replace bra they cost expensive!
Old Feb 9, 2008 | 05:35 AM
hotboxn's Avatar
Team Echo
i had 19x7.5 r1 racing rims back in 05 for about a year running some 215/35/19's and they worked out great, rubbed just a bit on the inner plastic at full lock. Lifted the car up a bit though :/ just more reason to get a drop
Old Feb 11, 2008 | 04:45 PM
Just1n's Avatar
Wagonistas
Im running 19x7 racing Harts with 215/35/19s whats RSL?
Old Feb 11, 2008 | 11:01 PM
Big_Jim's Avatar
My first set of 19's were Konig Holes, 19x7.5. I had 215/35/zr19 Dunlop SSP's on them. I was dropped roughly 2.5" all the way around. I had to put 5mm lug spacers in the rear so they wouldnt rub on the inside swing arm.
Next set of 19's i had were Axis Crux. 19x8 staggered offset. 45mm in the front, and 35mm in the rear. i had 215/35/19's on these too, but these were general's. These rubbed in the back with the 5mm spacers on, so i had to take them off.
Both sets of wheels rubbed at full lock.
Old Feb 12, 2008 | 03:44 AM
devskinner's Avatar
thanks for all the feedback guys .. rsl's are a golden apple corp wheel (baby brother to ADR's) , so i went with a 215/35/19 generals with a 5mm spacer in the back .. and ya i am droped 2" .. everything works great .. i will have pics up soon
neckbonenick
Oct 26, 2006 03:00 AM
TheRock
Scion tC 1G Wheel & Tire
24
Oct 3, 2006 02:58 AM
active9x
27
May 20, 2006 02:49 PM
XEPHON
Aug 20, 2005 12:50 AM
Patvonholt
9
Apr 6, 2005 11:58 PM
