2004-2006.5 [NCP61]
Please help me find a post...
Old Feb 13, 2008 | 04:37 PM
thegermangemini's Avatar
Default Please help me find a post...
Hey everyone. I am looking all over scionlife for a post on DIY xA headlight customizing. The one in particular was painting the bottom lip a platinum gray color. I wish I had more info. Anyone remember this? I will be forever in your debt!
Also, where is the DIY for installing the xA spoiler? Thanx all! :D
Old Feb 13, 2008 | 04:58 PM
bBlover's Avatar
Not sure on the headlights but here's how to install the spoiler. http://www.trdsparks.com/displaypart...7&parts_id=335 there will be a "button" that says installation manual on the right hand side of the page. Just click it and load the PDF then print and you're good to go. GL!
Old Feb 13, 2008 | 08:39 PM
LeroyJMC's Avatar
Looks like the pics are dead, but is this the headlight post that you're looking for?
https://www.scionlife.com/forums/viewtopic.php?t=161683
Old Feb 13, 2008 | 09:02 PM
dzxa06's Avatar
The spoiler was the one mod I had the dealership install. You need a special tool for the install for i think they are called Rivnuts.
Be careful before you start punching holes in your hatch.
Old Feb 14, 2008 | 07:27 PM
Ugh! Don't tell me that! Thought this was gonna be easy...
Old Feb 15, 2008 | 12:24 AM
simplyred's Avatar
it is easy, just scarry if you think about it. the rivnuts take a little thinking to get them compressed right. you will need 2 wrenches, a bolt, a couple lock washers, regular washers if you need to fill the space, some nuts and some nuts.
I know that this writeup sucks, but here.... bolt then washer/s then nut ( bigger size than the bolt, than lock washer and you have to put them together so that the lock washer holds the rivnut still while you turn the bolt... one wrench on the nut and other on the bolt... if you do it right the rivnut stays still and the bolt is tightened into the rivnut and will start to compress... just get it started and in the hole on the hatch than remove the bolt and add a couple more washers to get the rivnut to compress more...
I think that I just repeated myself..... dam sleep depervation... it sounds confusing, but the others out there like me that have done this mod themselves know what I am talking about.
GoodVibes
Jun 27, 2015 05:29 AM
NewBox06
Feb 3, 2015 12:36 PM
