2004-2006.5 [NCP61]
HELP PLEASE STEERING WHEEL SHAKING!!
Old Feb 14, 2008 | 07:05 PM
carlitoselcool1's Avatar
Default HELP PLEASE STEERING WHEEL SHAKING!!
YES I NOTICE THAT WHEN I GO OVER 60MPH MY STEERING WHEEL STARTS TO SHAKE A LITTLE BIT THEY TOLD ME THAT I HAD TO BALANCE THE TIRES, BUT ALSO THE DEALER IS TELLING ME THAT I HAVE TO ALIGN IT AND BALANCE IT BOTH AT THE SAME TIME ANY SUGESTION WHY THE SHAKING THANKS
Old Feb 14, 2008 | 09:55 PM
Psyco565's Avatar
It's exactly as the dealer said, you need an alignment and your wheels balanced. And please refrain from typing in all CAPS it's against the forum rules.
Old Feb 15, 2008 | 12:15 AM
simplyred's Avatar
also, if you have aftermarket rims you might want to consider some hubcentric rings.
Old Feb 15, 2008 | 08:57 PM
thanks for your help but the balancing and aligment is in all 4 tires or what ?
Old Feb 15, 2008 | 10:37 PM
Zillon's Avatar
They'll rebalance all 4 wheels and tires, and re-align the front end.
I had the same problem when I picked up my car off the lot. Took it in and told them to realign it and balance the tires, and it solved the problem.
Old Feb 16, 2008 | 05:15 AM
oldmanatee's Avatar
is the shake up & down or side to side? get all 4 tires balanced, look for cupping and unless you have lowered it or hit some nasty potholes, I'd hold off on the alignment...
Old Feb 16, 2008 | 10:34 PM
thank you guys for all the advices really helpfull
Old Feb 17, 2008 | 12:31 PM
badbasic's Avatar
vibration in the front end is ALMOST always balancing issue. pulls to one side r alignment issues. the only other thing is damaged steering components which you shuldnt have this early in the game unless u radically changed all ur suspension geomatry.
Old Feb 18, 2008 | 01:56 AM
so yes i finally got all my four tires rotated and balanced and the problem is till a fact, so other suggestion, i cant believe the fact that i spent 40 plus tax and still my steering wheel is shaking after 80 mph really annoying help please thanks
Old Feb 18, 2008 | 07:14 AM
bB2NER's Avatar
Music City Scions
You either have a bent rim or the place did a half azzed balance job. Did they Load Force balance the wheels/tires prior to balancing.
Have you tried moving the front tires to the rear and seeing how it does then? You might be able to narrow down which one is at fault.
Personally I'd take them back and have a manager do the balancing. They either missed something (bent wheel) or their machine is not right. You should be able to look at the tire while it's spinning and see if it is true or not. Good luck and don't take NO for an answer. Get what you paid for! It's gotta be something simple that they missed.
Old Feb 18, 2008 | 01:11 PM
really appreciate all your help, i did not see when they did the balancing of the wheels but i did see when they rotated the tires, so yes i guess i will have to take it to the toyota dealer and have them do a professional work. i was thinking that maybe it is something on the steering system or something i really dont know i lets see now how more much money i have to spend at the dealer thanks for all of your suggestions thanks a lot guys
Old Apr 8, 2008 | 08:57 PM
PagingDRb's Avatar
im assuming that you already got this fixed but i dont think anyone asked this question yet. When you're going 60+ does it constantly vibrate or is it only when you apply the brake? If it only happens when you apply the brake then you have build up on your rotors (most people call it warped rotors). What this means is that its tiime for a brake job.
Old Apr 8, 2008 | 09:22 PM
no i have not fixed yet it is still vibrating after 80 mph and is not when i brake it is all the time so is not the brake thanks any other suggestion
Old Apr 8, 2008 | 09:40 PM
Zillon's Avatar
Did you buy your car new or used?
Old Apr 9, 2008 | 01:10 PM
used
Old Apr 9, 2008 | 02:15 PM
stonecoldnimrod's Avatar
i've heard you should get the car alligned once you have it lowered, but honestly, i haven't had a problem with my xa after a set of tanabe df210's and no allignment necessary. ... is that normal?
Old Apr 9, 2008 | 02:57 PM
Zillon's Avatar
Carlito, you should've taken the car back to the dealer when you got it and demanded they fix it. Now it's too late.
The reason for the post-lowering alignment is to prevent abnormal tire wear. I'd suggest getting it checked out.
Old Apr 9, 2008 | 09:22 PM
thanks everybody
Old Apr 9, 2008 | 11:30 PM
Zillon's Avatar
Well, what I meant is that it's too late to get them to fix it at their own expense,
I would go and talk to their service manager and tell them that they did not properly balance your wheels/tires when you were last in.
Old Apr 10, 2008 | 08:48 PM
thanks
