PLX Devices SM-AFR Wideband Controller
Old Feb 14, 2008 | 08:15 PM
xa007xa's Avatar
Default PLX Devices SM-AFR Wideband Controller
Anyone have this installed? If so, did you throw a CEL? How did you wire it up?
Old Feb 20, 2008 | 05:14 AM
365Motorwerks's Avatar
Default Re: PLX Devices SM-AFR Wideband Controller
No I don't have one....but I was over at PLX last week checking out the gauges in person and they do look slick, it is nice that you can use one gauge hooked up to multiple sensors and toggle through them.
As for the CEL the gauge is a stand alone unit and does not mess with the car in any way you will not trigger a CEL.
Install guide http://www.plxdevices.com/Installati...UsersGuide.pdf
Old Feb 20, 2008 | 12:23 PM
xa007xa's Avatar
i'm not talking about the gauge. i'm asking about the wideband controller. supposed to replace stock narrowband and sensor and emulate narrowband to the ecu so that it won't throw a cel. i have it installed, but i am throwing cel p0031 which is for o2 sensor bank 1 heater. i have added 20 ohm 10 watt resistor across heater and ground wire and am still throwing cel. just frustrating cause i've tried wiring the resistors at ecu and at o2 sensor plug. decided to just have a 3rd bung welded on.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
Sgtfluffy16
Sep 30, 2015 01:42 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
