question on making your shifter shorter
Is there any way that you can "make" a short shifter? What I'm saying is to cut like 3 inches off the stock shifter? I dunno, maybe thas just dumb? What do you think?
A lot of short shifters do more than just shorten the part at the top. They also make the part after the pivot that connects to the shift cable longer. You can technically have a short throw shifter and still ahve the stock **** height.
Just get the TWM. Shortens the throw like 35% and lowers the **** 2". I love mine
If you really want to do it ghetto style.....use a dremel to cut it as short as you like and then use a tool to re-thread.
I would follow reign's advice on getting the TWM....but hey it's your car
ill probably cut it down till i get a short throw, b/c its not ridiculous like taking off your muffler just so its louder. your not damaging anything and it will look better if u do it right imo
I would never do it, but I have driven a friends car that was just glued back on- It was fine
sIcKsCiOnS
DelMarVa
Scion Tuners
honeslty, if u don't know wut ur doing....don't do it, but its ur car, not gonna make ur choices for you...
i understand ur saying that u want shorter shifter, cutting it will do the trick, but if u want shorter shifts, go with TWM
but with the money issue, cutting it will do the trick, just make sure u do it rite
yeah, I was gonna cut like 2 inches off the shifter today and then i ran into a problem. The shifter stick gets bigger like halfway down, so the little silver ring were the leather is attached won't go down. so unless you make that ring bigger, maybe by drilling it, cutting it will be useless.
NonStopTuning
Jun 29, 2015 07:42 PM
fluxingnation
Dec 26, 2014 04:28 PM
