Need advice on wheels...will these fit?
Old Feb 20, 2008 | 02:56 PM
thinline's Avatar
Default Need advice on wheels...will these fit?
I'm thinking of buying wheels for my 05 xB. I'm looking at 17x7.5 with a 40 offset. Would anyone know if there will be any fitment issues? The car is stock now but I will be putting in Tein H Techs. Also, what size tires should I go for?
Thanks.
Old Feb 20, 2008 | 05:35 PM
Buebie's Avatar
MN Scions
I'm not positive, but I think you need the rear hub shims with a 40 offset.
Old Feb 20, 2008 | 07:01 PM
burstaneurysm's Avatar
That will fit fine... you might WANT hub shims to push them out a bit, but you don't need them at all.
Go to tirerack.com, they will recommend a tire size for whatever wheel you want.
Old Feb 20, 2008 | 08:06 PM
CamoTrav's Avatar
My Trak Lites were 17x8 +42. i ran a 215/40 tire. No rubbing issues and i was on S-techs and Basic Coilovers.
Like above a 10mm or even 15mm spacer would help bring the wheel closer to the fender
Old Feb 20, 2008 | 09:26 PM
I'm running a 10mm spacer in back (18x7.5 +42)... they could stand to get pushed out a bit more.
Old Feb 21, 2008 | 12:50 AM
thinline's Avatar
A few more questions...
Are shims and spacers the same thing?
Are they for appearances only or are there any negative effects to not using them?
I do have passengers occasionally so I worry about tire rub.
Thanks again!
Old Feb 21, 2008 | 01:03 AM
CamoTrav's Avatar
The shims/spacers we are speaking of go behind the rear drum assembly.
I never rubbed with my Motegis when I had a 15mm spacer and my Coilovers almost to the bottom on the front and rear with passengers.
The only thing i would recommend when getting a wheel spacer one that goes between the wheel and the drum is that it is hub centric and has extended lugs
polychromaticfetus
Scion tC 2G Forced Induction
Sep 9, 2015 12:12 AM
scionlife
371
Jun 2, 2015 11:00 PM
Kata
Mar 2, 2015 10:46 PM
StatuSCheckA
Scion tC 2G ICE & Interior
Dec 4, 2014 03:15 PM
gularti
Dec 4, 2014 01:21 PM
