oil changes
Old Feb 28, 2008 | 01:51 AM
Smooth_J's Avatar
Default oil changes
I hope this doesn't turn out to be a war, but I need to ask anyway...
How often does everyone change there oil? As per Toyota, they say every 5000 (I don't trust that number). I say every 3000 (since I am usually on the highway a lot anyway - ~2 hours a day). Which one is it?
Btw - Toyota is going to do mine since its still free. They "claim" to use a blend.
Old Feb 28, 2008 | 01:59 AM
silverstreaktc's Avatar
the last time they did mine they left my TRD oil cap on the exhaust manifold...stupid...
Old Feb 28, 2008 | 02:02 AM
Yanki01's Avatar
since my first 3 were free, i changed it probally around 3-4k miles. Although i dont use but 6-700 miles/month. Ive switched over to mobile1 full synthetic after the first 3 and change it every 5k miles or 5-6 months along with the Toyota filter. I also change the "washer" every other oil change.
Old Feb 28, 2008 | 03:29 AM
2007tC-T's Avatar
For a stock or lightly modded car, it's not really necesary to deviate from the oil change schedule Toyota recommends.
Old Feb 28, 2008 | 03:58 AM
MaxxFMTC's Avatar
Same here- I just do mine every 5K using mobil1 syn. Been doing that on all my previous cars with no problems whatsoever.
Is there any advantage to using the Toyota (or K&N for that matter) filters over Fram? And what "washer" are you referring to?
Old Feb 28, 2008 | 04:02 AM
cmv138's Avatar
how good are the OEM filters ?
Old Feb 28, 2008 | 04:24 AM
azureloki's Avatar
[quote=Is there any advantage to using the Toyota (or K&N for that matter) filters over Fram? And what "washer" are you referring to?[/quote]
the washer is the little circular thing on the drain plug of the oil pan, i don't change it but i would like to know the difference it makes to change it...
Old Feb 28, 2008 | 04:28 AM
Yanki01's Avatar
good enough to me. i switched after doing some research and reading on the DIY: Oil change thread....
https://www.scionlife.com/forums/vie...asc&&start=100
there is a difference in mobile1 and toyota filter as in size and some other internal things. I thought id be safe and go with the toyota filters since their made expecially for the tC.
those "washers" is the washer that goes on the drain plug when you put it back on under the car after you let out the old oil. i change it every other oil change hence in the pic on why i bought 5 washers for 10 filters. i bought my filters (10 pk) and "drain plug gasket" (washer) from TRDSparks.com for all under $50.
http://trdsparks.com/displayparts.ph...1&parts_id=970
http://trdsparks.com/displayparts.ph...&parts_id=1358
im still using mobile1 oil but recently thought about switching to royal purple. still have about 2k miles to think about it tho.
Old Feb 28, 2008 | 04:34 AM
MaxxFMTC's Avatar
OK- now that I know what "washers" we're referring to, I can (somewhat) explain why they need to be replaced occasionally. They're made from rubber, and act as a gasket which keeps you're oil from dripping out of the drain plug. If it dries up and cracks, oil will drip out of it. I typically don't bother replacing mine that often- but if it starts looking "weird", I will replace it. When changing your oil, it helps to give that washer a light coat of NEW oil (just like you put around the oil filter gasket) to help it seal better and keep it from drying out.
Old Feb 28, 2008 | 04:38 AM
trialsindude's Avatar
Strictly Scionized
10,000 miles between oil changes....
Old Feb 28, 2008 | 04:59 AM
GammaTNT's Avatar
5k miles between oil change, I change my washer evey 15k miles
Driving on Highway don't require frequent oil change. Driving in the city's stop and go traffic will need more frequent oil change,
Old Feb 28, 2008 | 11:43 AM
skiboarder72's Avatar
normal oil changes at 5k,10k,15k, switched to mobil 1 syn at 20k, changed at 30k, soon to change at 40k
Old Feb 28, 2008 | 12:02 PM
digndoug's Avatar
This should also depend greatly on starts. If your like me, and drive maybe 20 miles a day but start your car maybe 3-4 you should change every 3-4k if you drive a lot of highway like 50-100 miles a day an start your car say twice (you get the idea) You are going to be fine waiting 5-7k Also don't forget its also every 3 months. (except when its freezing out lol)
his also depends on oil, syn. is designed to run longer w/o frequent oil changes. such as the first time 4-5k second time 7-8k third time 10k all others 10-15k
As for Filers, personal opinion, these only need to be changed EVERY OTHER TIME. I normal change it out cause i drive maybe 9k a year and do 3 oil changes a year.
The washer/gasket ring should only be changed when needed/damaged
Old Feb 28, 2008 | 12:50 PM
Smooth_J's Avatar
I did my first oil change at or around 3200 mi, now I am doing my other one around 7000mi. Like I said - I do a lot of highway driving (rpms are at least @ 3500)... so its "safe" to change the oil every 5 or so instead of 3? Please let me know - thank you all!!!
Old Feb 28, 2008 | 12:53 PM
digndoug's Avatar
Of course its safe. The dealership even specifies 5k. If you drive a little harder or not many miles a year you can do less. As for rpm's thats normal. Just keep in mind that it should get done every 3 months.
Old Feb 28, 2008 | 01:57 PM
AAG's Avatar
AAG
DeepSouth Scions
You're wasting money if you are doing your oil changes at 3k miles. If you are using conventional oil, 5k miles oil changes are fine & you can go quite a bit longer on synthetic. I plan to go synthetic and do 10k mile oil changes (replacing oil filter at 5k miles).
Visit http://www.bobistheoilguy.com/forums/ubbthreads.php its very helpful and informative website.
Old Feb 28, 2008 | 02:36 PM
amp0804's Avatar
Every oil filter that I have got came with the drain plug washer...Sometimes its hidden in that little box though.
Old Feb 28, 2008 | 03:46 PM
MaxxFMTC's Avatar
Are these the Toyota ones? Cuz I always get Fram, and they never come with the "____ plug" washer. Of course, it is Fram- so what do you expect?[/quote]
Old Feb 28, 2008 | 03:47 PM
cavalierkid888's Avatar
Like some people have already stated. If your doing mainly highway driving the oil will stay cleaner and personally I would NOT change it every 3k. Do it every 5k and you'll be just fine.
I also do mostly highway driving and my I haven't had the oil changed in a little over 4k miles. I just checked the level a couple days ago and the oil was still really clean.
Old Feb 28, 2008 | 03:59 PM
nominal_asu's Avatar
Manual says 6 months, if it wasnt safe it wouldnt be in there or they would get sued
yupinmytC
22
Jul 27, 2024 07:08 PM
mudguy
Oct 22, 2015 04:31 PM
crimson_sinn
Sep 25, 2015 09:41 PM
Klashan
Sep 24, 2015 12:39 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
