camber necessary? on hotchkis lower spring?
Old Mar 3, 2008 | 01:52 AM
danielv's Avatar
Default camber necessary? on hotchkis lower spring?
^i have hotckis lowering springs i was wondering if i need it. 1.7 front and 2.0 back. because hotckis only has rear.
Old Mar 3, 2008 | 02:07 AM
Yanki01's Avatar
you only need the read and if you want to keep some even tread on your rear tires, then yes. I just got the hotchkis camber links installed 2 weeks ago and noticed the difference in the stance. I just got new tires and now they should last a bit longer than without it.
this is how it looked before.
before the negative camber was i believe -1.7-9* now i think its -.2-4*. Im going to go back to get it straighten out to 0* both sides. i dont have any current pics of how it looks, ill try to get some tomorrow.
Old Mar 3, 2008 | 03:37 AM
Tcguy85's Avatar
i got my camber within spec just from getting an alignment. i didn't need a camber kit and my camber is fine.
Old Mar 3, 2008 | 04:04 AM
WendysOrBust's Avatar
Yeah, that looks like almost 3 degrees of camber on that back wheel. Thats allot, and if you decide to get your camber zeroed out it will reduce your lateral grip greatly. Running anything under 2 degrees of camber will not cause uneven tire wear. What will cause the insides of your tires to wear our very fast is incorrect toe.
ScionDP
Mar 1, 2015 10:57 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
mark13018
Feb 6, 2015 08:57 AM
Scionxa180
16
Dec 8, 2014 04:00 PM
hydrogen
Oct 29, 2003 04:58 AM
