New Deck Small Problem
Old Mar 14, 2008 | 11:07 AM
alltattooed's Avatar
Default New Deck Small Problem
Hello All,
Iinstalled my new Pioneer Deck last night and it sounds great. I am surprised how much better the factory speakers sound with a aftermarket deck VS the factory one.
How ever i do have 2 small problems i hope someone can help me with.
1) On the wire harness i purchased for the factory harness ( NOT THE DECK HRNESS) the is a wire called POWER ANTANA nd on the harness for the deck there is no wire calledd that Do i jus leave it be o an i supost to wire it to some thing else?
2) My second problem might have something to do with my frist I have evry little to no radio reception. With the factory deck i had great recption but not know. And before some one asksYES i did pug the antana in to the new deck.
Can any one pease help me out?
Thanks
Old Mar 14, 2008 | 01:19 PM
Improbcat's Avatar
EDIT: ignore, I was misinformed.
Old Mar 14, 2008 | 03:38 PM
tanakasan's Avatar
Do a search for "radio reception" or the like.
The xB uses a powered antenna as Improbcat said and needs this connected to +12v. I cannot remember exactly which wires they were. Lots of posts on this will help you out.
G/L!
Old Mar 14, 2008 | 03:42 PM
Improbcat's Avatar
Old Mar 14, 2008 | 07:19 PM
tCscotty's Avatar
Hook the power antenna wire up to the deck. Use the remote wire on the deck. It should be blue. The xB needs power to the antenna. Thats why your getting bad reception.
Old Mar 14, 2008 | 10:47 PM
Thanks for the replies. I will go and hook up the ant wire and see what happens.
Old Mar 14, 2008 | 10:48 PM
tanakasan's Avatar
^^You'll be golden!
Old Mar 17, 2008 | 07:51 PM
erikcooper's Avatar
I have had this problem chronically even though I have said wire hooked up
Old Mar 18, 2008 | 05:14 AM
tanakasan's Avatar
Check and make sure :
A) you have the correct wire hooked up. I *believe* there is a blue AND a blue w/yellow or white trace.
B) Make sure with a DMM that there is +12v there when you turn the car on.
G/L!
Old Mar 18, 2008 | 07:43 PM
erikcooper's Avatar
I have the blue wire that says "power antenna" hooked to the wire for the new deck that says the same thing.
Old Mar 18, 2008 | 08:43 PM
tanakasan's Avatar
^^Then see step "B" next...
It looks like a brown w/red trace wire according to a .pdf diagram I have. The xB wiring harness will not say "power antenna" on any wires.
Use the DMM, Luke!
Old Dec 21, 2008 | 05:19 AM
Tankgod's Avatar
thank you for posting this. It helped greatly. Although on mine it was black with red.
Old Dec 21, 2008 | 05:59 PM
tanakasan's Avatar
Glad it helped!
Ya, my bad there! Black/Red!
I used the wiring diagram for an '04 xB (Thanks Jeff/bB2NER!) and it was "B R". A meter will be the key. Needs to be hot with the acc'y on OR radio on.
Robert
CLICK for>>2004 Scion xB Stereo Wiring Large Image
[/url]
evolving_machine
Jan 13, 2015 08:04 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
cwong1001
Dec 3, 2014 03:30 AM
TJ
27
Feb 8, 2004 12:20 AM
supaguy
Dec 15, 2003 01:28 AM
