2005 tC Paint Issues
Old Nov 20, 2004 | 06:10 PM
garciaog's Avatar
Default 2005 tC Paint Issues
Has anyone out there had problems with the paint on `05 tC's? My Azure Pearl tC has yet to suffer from any other nuisances mentioned in these forums, but I have noticed some "stains" which appear to be under the clearcoat. Also, while driving on the freeway, my car was splattered by mud from a passing truck, and when I attempted to clean it off, it seems as if the paint was stained. I am reluctant to have warranty repair done, because blue paint is hard to match, and aftermarket paint jobs sometimes do not hold up over time.
Any suggestions?
Old Nov 20, 2004 | 06:40 PM
lyrictenor1's Avatar
try using a clay bar to get out the stains
Old Nov 20, 2004 | 07:53 PM
Rich_Manas's Avatar
we had a scion in which the tarp covering the cars as it was shipped left a weird mark on the paint from the moisture inside the cargo freight. a tsb was released explaining how to fix it with carfeul use of a heat gun mixed with a polish that removed the stain.
if this is the stain your reffering to go to the dealer that you bought your scion and have them inspect the paint. the paint on the car is covered under the warranty as long as its not wear and tear.
Old Nov 20, 2004 | 08:40 PM
ShadyEye16's Avatar
this problem is nation wide, I've noticed it aon SEVERAL of my Scion's and i'd suggest that you contact your local dealer and ask that SCION cover it under warranty!
Old Nov 20, 2004 | 09:11 PM
garciaog's Avatar
Thank you for the input, Scion reps. Now that the problem has (hopefully) been identified, I can rest a bit easier. Have any Scion people seen the fixed results?
The staining is eerily similar to that on my `87 Camry, but that was on 16-year old paint! I just hope that the hood won't need repainting.
Again, thanks to all for their input.
Old Nov 20, 2004 | 10:19 PM
Sorry... I was referring to the mud stains for utilization of the clay bar
Old Nov 21, 2004 | 12:29 AM
Cybergypsy's Avatar
The paint on all scion's chip to easy
Old Nov 21, 2004 | 03:30 AM
intakeonly's Avatar
Default i bought a MOTHER's clay bar kit
so i used a clay bar to try to remove the bug stains
no luck...
and is ugly as freak
i'll post some pictures soon
http://members.cardomain.com/intakeonly
Old Nov 21, 2004 | 04:12 AM
garciaog's Avatar
At least I'm not the only one. The paint quality is reminiscent of Toyotas past (80's-early 00's). I will be taking my tC to the dealership ASAP. Have any owners had any experience with this issue from beginning to end?
Old Nov 21, 2004 | 04:28 AM
Helter's Avatar
Buddy I have exactly what you've experienced. The dealer saw it before giving it to me. I never really noticed it cause I have the black one. Anyway they just repaired it. I think they repainted the hood cause you can't really remove it by just using a clay bar cause its underneath the coat. You should contact your dealer.
chowdahound
May 20, 2015 06:46 AM
JPuehl
Scion tC 2G Wheel & Tire
Jan 22, 2015 02:44 PM
cid_mcdp
Jan 5, 2015 02:45 PM
AbsoluteRedtC
Dec 31, 2014 06:18 PM
minter66
Dec 15, 2014 01:45 PM
