Got my Kaminari........
Old Mar 20, 2008 | 05:00 AM
BZinn1's Avatar
Default Got my Kaminari........
That is all I have for now.........they put the wrong latch on the hood and it is like 1.7" too long so I am making a bracket to remount the hood clip latch further down......had to cut a bunch of the support off and make a new bracket to mount the thing to and tomorrow I gotta make a mount bracket fro each side of the latch on the radiator bracket........when it is done it should be stronger than the stock mounts though.........
More photos tomorrow..........it is dark and raining now..........
Old Mar 20, 2008 | 05:06 AM
SVicksTC's Avatar
Persoanlly i would of been ____ed off about the latch being wrong, i would not want to spend all this money on a hood and have to modify it to work....They claim its a direct replacement part and thats not right....I would call and complain about this however i do respect yuor effort in making it work post more pics please...........
Old Mar 20, 2008 | 05:07 AM
Garage1217's Avatar
wow the latch thing is odd, did ya call Kaminari on it and take pics..? Make sure to notify them
Old Mar 20, 2008 | 05:13 AM
1_kLEan_tC's Avatar
x2^^^
BZinn1's Avatar
Yeah we will let them know.........I most likely will be just using hood pins anyway and can the latch all together.........it is weird though..........fittment other than that is perfect........unless the 08s have something differant going on withthe latches onthe car.........I will be up first thing inthe mornign and get photos up........it looks really good onthe car.........it closes and latches but I need to finishthe latch mounts on the radiator.........couple of hours work and $5 in parts from home depot........
Old Mar 20, 2008 | 06:09 AM
OpTiMi5t's Avatar
Team Sushi
that maybe wat the problems was, your car is an 08'
Old Mar 20, 2008 | 08:47 AM
tico4csun's Avatar
Team ScionTific
Shouldn't be much of a difference. I could be wrong
Aside from the headlamps and grill, the hood looked pretty much the same to me.
Old Mar 20, 2008 | 10:05 AM
Nick06tC's Avatar
wow, mine was eprfect. maybe its the year or something.
Old Mar 20, 2008 | 02:31 PM
BZinn1's Avatar
Yeah I think they changed the latch onthe 08..........I almost got it rebuildt though.........nothing a drill a dremel and 4 nuts and bolts cannot fix.......LOL........
Old Mar 20, 2008 | 03:05 PM
Elijahtc's Avatar
hate to tell ya this but all ya had to do was unbolt the latch on the car move it down and then rebolt it. it is designed to be moved. My kami was PERFECT and so has everybody else's. I did have to move my latch down and move my bump stops to get it fitted tho. It's gonna take u anywhere from 3--5 tries to get it fittd perfectly.
Old Mar 20, 2008 | 03:12 PM
BZinn1's Avatar
Not on my latch........the support bar goes all the way to the bottom of the latch........think they either put wrong piece on or redid the latch for 08......but on the high side I will have the only hidden latch as it now sits below the doc I plate and I modded the pull part as well........calling kaminari ina few minutes........to get measurments of the latch on hood to see if they put wrong one or if 08 is designed differant.
Old Mar 20, 2008 | 03:52 PM
Elijahtc's Avatar
Sounds to me like the car is different cause the latch for kami is the same on all the ones I've seen. I don't see why they would change the latch tho. U shouldve had 3 bolts u can losen to to raise/lower or move side to side for the latch on the car.
Old Mar 20, 2008 | 04:32 PM
20tCDude05's Avatar
Oh no, I ordered the hood also. I hope my latch is fine.
Plus, mine is a 2007.
Old Mar 20, 2008 | 04:36 PM
Elijahtc's Avatar
U won't have any problems I assure u. Just adjust the latch on the car. It has 3 bolts that hold it on that u can losen to give u some adjustment.
Old Mar 20, 2008 | 06:11 PM
BZinn1's Avatar
Yeah from what I have found the latch is just the wrong length onthe hood.......it is 1.5" too deep.......the latch mechanism only has .25 in any direction of movement.......but to be honest the new bracket i made is stronger and is working perfect........attached some final photos of the hood installed........works perfect.
sorry they are not high def photos.........I do not have a nice camera.....
Old Mar 20, 2008 | 06:45 PM
Dilirious's Avatar
Not bad, about how long did it take you to get it installed and everything?
Old Mar 20, 2008 | 06:53 PM
Elijahtc's Avatar
On my version which I just had to move the latch on the car I think it took us maybe 20 minutes and that was to completely fine tune it. I promise u won't find a better fitting cf hood. Just wish they would make a hatch to match. Ha ha
Old Mar 20, 2008 | 08:37 PM
BZinn1's Avatar
If you do not include the drilling for the washer nozzles or the latch issue..........it took under 20 minutes to install..........old hood took longer to get off than this one to install.fitment is perfect..........they did a great job of making it.........just a weird latch.......
Old Mar 20, 2008 | 08:48 PM
Joyride's Avatar
Does the hood come with "hole placement marks" for the window washer nozzles? Very interested in this hood probably next on my list.
Old Mar 20, 2008 | 09:01 PM
Elijahtc's Avatar
Yeah it does. I just run mine without the nozzles. I think it looks cleaner and I don't ever use it anyways. Just clean the windows when I am stop at a gas stations.
