Removing Rust
Old Mar 20, 2008 | 03:56 PM
lildevil23's Avatar
Default Removing Rust
Hi folks..
Just swapped my winter wheels for the TRD's yday night and today morning realized that the brake drums have a layer of rust on them. What is the easiest or most reliable way to get rid of this..permanently??
Old Mar 20, 2008 | 04:12 PM
vettereddie's Avatar
Most reliable is to clean them up and put on an anti-corrosion paint. You can try these from Eastwood:
Rust Dissolver
Brake Drum Coating
On my last car the OEM color was not black, so I used a stainless steel high temp paint. This needs heat to be activated, on headers the exhaust gas does it, for brakes you may need to bake the drum.
Stainless Brush-on Paint
Old Mar 20, 2008 | 04:35 PM
bigpapa's Avatar
I would expect that the rust is superficial and should disappear with some heavy braking.
Old Mar 20, 2008 | 04:37 PM
tCTaco's Avatar
Drum Brakes? On the g2xB??
Old Mar 20, 2008 | 05:52 PM
I just caught that, xB2 has 4-wheel disc. I have the 1gen with drums. If the rust is on the smooth braking surface of the rotor, it should come right off with liberal application of the brake pedal. DO NOT paint the rotor surface. if the caliper or center hub are rusting, those can be cleaned and painted with caliper paint.
Old Mar 20, 2008 | 06:07 PM
lildevil23's Avatar
thanks vettereddie..my bad..dont even know why i typed drums..when it should have been rotors!!..
Old Mar 20, 2008 | 07:59 PM
bigpapa's Avatar
I've noticed superficial rust on my rotors when the car has sat in the driveway over a rainy weekend.
Old Mar 20, 2008 | 08:06 PM
chicotunner07's Avatar
^^then u drive and ur wheels look like you drove through a dust storm!!! I hate that!
yhwhdesign
Jun 11, 2021 03:34 PM
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
StxArOne
Aug 21, 2015 06:44 PM
Mjdavis1994
Jul 18, 2015 04:29 AM
excessads
Jul 13, 2015 11:41 AM
