need help with drum brakes
Old Mar 22, 2008 | 08:04 PM
SFScionGuy's Avatar
Default need help with drum brakes
Sorry, couldn't find any DIY or posts for drum brakes on the scion xb. When should I change my drum brakes? I have 60k on them now. I changed my fronts around 40k. Questions:
1. Are drums easy to change, I supposed just as easy as the fronts.
2. What are the parts and cost?
3. I rather do it myself, or is there something special that the dealer needs to do.
Thanks.
Old Mar 22, 2008 | 08:17 PM
tkevin07's Avatar
FOr me the drums are a bit hard to change because of all the springs and adjustments u have to do, and typically they last quite a while my dad's van has the drum brakes in the rear for 110K now and still does not need changing, the rear doesnt stop the car much its only when u slamm on ur brakes, the fronts are the usual that kicks in.
parts are usually 45-75 bucks depends on where you get them, any drum brakes work the same so if you look it up you'll see it a bit harder, bbut after your first time u should be able to do it again, so i just take mine to the shop
they sqeal by the way when u need to change
Old Mar 22, 2008 | 08:23 PM
SFScionGuy's Avatar
i see, sounds like i should take mine to the shop whenever they wear out. I don't really want to do adjustments or whatever haha sounds like something i will screw up.
Old Mar 22, 2008 | 09:12 PM
tkevin07's Avatar
haha u can always take it to get a free inspection some places justt look at it and measure how much u have left
Old Mar 23, 2008 | 01:35 PM
jct's Avatar
jct
drums are hella easy to work on
Old Mar 24, 2008 | 01:35 AM
Shakerhood's Avatar
I like doing Disc Brakes over Drums, but they are not that hard. Make sure you do 1 side at a time that way you can look at the other side for a reference.
gqdabien
Oct 8, 2015 05:36 PM
Klashan
Sep 24, 2015 12:39 PM
DannyBoy65
Sep 21, 2015 06:23 PM
axB
Sep 18, 2015 06:11 AM
Subaru86
Scion FR-S Aero & Exterior
Sep 14, 2015 12:39 PM
