What's the Best Header for Auto Transmission?
Old Mar 25, 2008 | 06:49 PM
zmcqdv's Avatar
Default What's the Best Header for Auto Transmission?
Wanna know which is the best 4-1 header to change to from stock for Auto transmission?
So far I heard from my frens, was don't change, because Auto Car needs back pressure, if the back pressure is reduced, I would loose out on low end and during pick up. Is this true?
If it's not true, then which is the best header out there tat gives the better edge over stock on all levels from low end to high end.
Weapon-R, OBX, Megan, DC... and so on... which one.
Thanks.
Old Mar 25, 2008 | 06:57 PM
bB2NER's Avatar
Music City Scions
I've got the ceramic coated stainless ebay one for 55 bucks coming. I've heard it helps to keep from having the trans downshift while going up hills. The tube sizes are larger than stock but not so large so they will lose lower end power. Can't wait to get it installed to see for myself. Anything other than stock will work great. I just couldn't bring myself to spend the big bucks on a name brand part that sits behind the engine outta sight.
Old Mar 25, 2008 | 06:58 PM
burstaneurysm's Avatar
I have the Weapon-R. The 4-2-1 design retains more of the low end torque than a 4-1 design.
Old Mar 25, 2008 | 07:30 PM
vettereddie's Avatar
I was going to say the exact same thing. It's less a question of brand than design type. If I were to buy a new one, I'd go with a 4-2-1 ceremic coated for low-end torque and less heat build-up. I don't know who all makes that design.
I currently have the Strup 4-1 stainless, I'll be wrapping it and hopefully will see at least a slight increase.
Old Mar 25, 2008 | 08:12 PM
bB2NER's Avatar
Music City Scions
I wonder how hard it would be to wrap the ebay one?
Old Mar 25, 2008 | 08:15 PM
CBSIMONSEZ's Avatar
Strup.
Old Mar 25, 2008 | 09:12 PM
Shouldn't be any more difficult than any other header. It's just tape. If you've ever had a sprained ankle and needed to wrap it with athletic tape, the same technique applies. Start at the top of each pipe, wrap down with an overlap then wrap back up. Just don't tape over the holes.
Old Mar 25, 2008 | 09:50 PM
bB2NER's Avatar
Music City Scions
I've been reading stuff about if you wrap the header it will cause cracks or rust to form. I think I'll just leave it bare. It is coated so it should be fine.
Old Mar 26, 2008 | 01:00 AM
stew32's Avatar
Since the auto would be shifting at lower RPM, I'd say a 4-2-1 header would be best. More expensive than the 4-1 headers that are out there. Since options are limited, maybe the MMW header since it's not coated but you can install the stock heat shield?
Old Mar 26, 2008 | 01:45 AM
zmcqdv's Avatar
Thanks for the feedback.
Still contemplating to choose between Weapon-R and OBX now.
I come across on ebay for OBX 4-1 header for 125.00.
And I checked that Weapon-R only have 1 type header on their website for xB, is it tat one which looks like 4-2-1
http://weapon-r.com/english/index.ph...oducts_id=6230
Which wud be better?
Will the Weapon-R loses out on High end compared to OBX due to it's design but better in LOW end (based on 4-2-1 against 4-1)?
Old Mar 26, 2008 | 03:44 PM
aalbertson3's Avatar
Go with the Weapon R! Most people are never high enough in the RPM range to feel the benefits of a 4-1 design.
Old Mar 27, 2008 | 04:42 AM
zmcqdv's Avatar
Ok. Thanks for the review and explanations....
Will try to get Weapon R 4-2-1 then.
Old Mar 28, 2008 | 01:49 AM
stew32's Avatar
Weapon R is MMW? I had this bookmarked a while ago...
http://www.precisionmuffler.com/id13...nce_header.htm
Old Mar 28, 2008 | 01:52 AM
firesquare's Avatar
Originally Posted by CBSIMONSEZ
Strup.
x2
Old Mar 28, 2008 | 04:19 PM
Yes they are the same company.
evolving_machine
Oct 21, 2023 01:16 PM
tckid21
Mar 12, 2017 09:16 PM
AstraXtreme
Feb 25, 2015 04:24 PM
JM Auto Racing
Dec 19, 2014 06:36 PM
eric_m
79
Mar 17, 2013 12:21 AM
