how to change brakelight on my box..
Old Mar 30, 2008 | 12:41 AM
ToasterOnWheels's Avatar
Default how to change brakelight on my box..
ok ok yes i know it must be the easiest thing but i could not figure it out. i tried searching but could not find a how to... so yes... my rear right brake light is out and i need help
Old Mar 30, 2008 | 12:47 AM
CBSIMONSEZ's Avatar
in each rear corner there is a panel that you pull out ( interior of the box ) reach inside and feel for the bulb you need to replace. Turn a 1/4 turn counterclock wise and pull it away from the housing. Replace bulb and re-install.
Old Mar 31, 2008 | 01:08 AM
thank you! oh my gosh it was so easy... silly me thought it would be difficult lol. thanks again. now i know for next time.
Old Nov 7, 2008 | 02:30 AM
hawaiiguy's Avatar
i'm trying to replace my dead third brake light (bulb #921)...i've removed the black plastic housing...but can't seem to slip off the bulb...the pic in the manual says to turn counterclockwise (while facing the front of the car)---it seems I'm straining, but it can't come off---I feel if i turn it any more, it'll break off instead!
Any tips?
Old Nov 7, 2008 | 04:26 AM
snowromance's Avatar
you don't actually turn the bulb. the bulb pulls straight out. if you want to remove the whole socket holding the bulb, that is what you twist cw and remove.
Old Nov 7, 2008 | 04:32 AM
hawaiiguy's Avatar
you kidding me! the pic in the manual looks like it telling one to turn it counterclockwise...I'll try it tomorrow...good night and thanks!
Old Nov 7, 2008 | 07:40 AM
hawaiiguy's Avatar
pulling it straight out isn't doing it for me...it ain't happening!
Old Nov 9, 2008 | 06:09 AM
hawaiiguy's Avatar
my bad in understanding your directions...yes, I had to first jiggle, then spray with silicone spray before it would turn to come apart...then pull straight out the bulb...
btw, those two screws on either side that holds the entire housing doesn'tdo jack...(I removed them, but the housing even wouldn't come off, and didn't want to break it).
But hey, I'm happy that I finally replaced it...it needed some lube to loosen!
Old Nov 9, 2008 | 06:26 AM
firesquare's Avatar
now some cars are down right impossible. (VW Jetta and New Beetle)
the 3rd brake lamp bulb sometimes will get very hot and melt the plastic. keep an eye on it. i personally am not a big fan of it. the bulb swells up and gets hot and sometimes will melt its own housing/plug. and a LEd bulb doesnt work too well unless you PM the master, snowromance
RY_TC07
Jul 18, 2017 05:18 PM
elwaylite
Apr 30, 2015 02:31 PM
mrsocks
Jan 20, 2015 01:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TinaXB
14
Dec 19, 2003 08:19 AM
