eD stealth box--DIY instructions?
Old Apr 7, 2008 | 03:08 AM
SoleLaced's Avatar
Default eD stealth box--DIY instructions?
Hey guys
Ive been looking into subs and boxes lately. I almost settled with just buying a generic box from bestbuy (lulz) and picking up an alpine sub. However, the more I look into eD's slim sub, I continually want that stealth box more and more.
Now Ive seen members on this forum making stealth boxes with 2 SQ10s. However, I want to make the version with 1 SQ10, just like how eD would make it. Does anyone have instructions on making one? I know it shouldnt be THAT hard, but I have never worked with MDF or have any woodworking skills. (how would I measure 1cF?)
In addition, is there a way to make the stealth box vented? eD suggest that vented boxes need to be @ 1.0cF Tuned to 35Hz or .7cF Tuned to 30Hz.
If someone can help me out with instructions or advice, Id love you.
LINKS:
Sub: http://www.edesignaudio.com/product_...roducts_id=106
Box: http://www.edesignaudio.com/product_...roducts_id=465
Old Apr 7, 2008 | 03:24 AM
O5_TRD_tC's Avatar
Hey Nikki,
If u need anyone to run the wires for you. Im your guy (again).
Installing the box itself is easy, it drops right in.
Old Apr 7, 2008 | 05:05 AM
datboiant's Avatar
Well if you buy the box from them, make sure you ask them how long it takes for them to make it since its custom order.
Old Apr 7, 2008 | 11:02 AM
SquallLHeart's Avatar
you just need to come out this weds man...
Old Apr 7, 2008 | 11:23 AM
JakeK's Avatar
i built one myself. Pretty easy. I just took the foam piece out, used that to make a top and a bottom for the box, then built walls where the top and bottom overlap.
Or i could sell you mine for alot cheaper than eD would. I blew my sq10 anyway(too big of an amp)
Old Apr 7, 2008 | 03:59 PM
SoleLaced's Avatar
oh man. How much did you want to sell the box for? I guess I can see I'd trung can enlighten me on how to build one.
Let meknow how much you want.
Ps: I'll see if I can come next Wednesday haha
Old Apr 7, 2008 | 06:59 PM
O5_TRD_tC's Avatar
u can see his dope LED swap
Old Apr 7, 2008 | 09:13 PM
JakeK's Avatar
hey, if you cover shipping, then i would let the box go for pretty cheap; lets just say MUCH cheaper than eD wants for theirs. Make an offer and i will probably accept because it isnt doing me no good sitting around collecting dust.
Old Apr 8, 2008 | 12:24 AM
SoleLaced's Avatar
^^ you got a PM sir
Old Apr 8, 2008 | 02:53 AM
SoleLaced's Avatar
does anyone have instructions on making a stealth box?
Old Apr 10, 2008 | 02:25 AM
SoleLaced's Avatar
Bump.
Does anyone have the dimensions of the box? I would like to know the shape and length of each side so I can create one.
Old Apr 10, 2008 | 03:39 PM
goofygrin's Avatar
It's the same size as the foam insert.
I've got the eD one with the SQ10 and frankly I don't like it. SQ isn't great and it certainly isn't all that bass-y. But for $200 it saved me a lot of time (otherwise I would have just built one).
Old Apr 10, 2008 | 04:02 PM
Hyghgynx's Avatar
I found this LINK for you. Hope it helps.
Old Apr 11, 2008 | 12:30 AM
SoleLaced's Avatar
wow thanks a lot!
My only question left is.... how do i mount the sub? I see that its recessed into the top (plate?). He said that he used a baffle, but how would I make that? Can I buy one that will owrk for the SQ10?
Also, how deep do I offset it so that it sits correctly flush with the top, or how its suppose to be?
Old Apr 11, 2008 | 04:19 AM
wazzu_coug's Avatar
Alight, heres the easy way. Trace the foam insert, cut out a piece of .75" MDF in that shape. Next make a simple rectangle box that has a total height of 4" and a volume of .5cF. Cut the hole out of the box and mount the subwoofer. Cut out a corresponding hole with a diameter of 10.25" out of the larger wood piece (the one which you traced of the foam insert). Nail the two pieces together.
Old Apr 11, 2008 | 04:47 AM
SoleLaced's Avatar
can you explain that one mroe time? I got lost
Old Apr 11, 2008 | 11:23 PM
SoleLaced's Avatar
does anyone have advice on mounting the SQ10 before I start buying material to make it?
Old Apr 12, 2008 | 01:14 AM
nebster's Avatar
screw it into wood?
Old Apr 12, 2008 | 01:15 AM
SoleLaced's Avatar
well isnt it recessed lower into the box? That way it wont fire and hit the floormat.
Old Apr 12, 2008 | 01:20 AM
nebster's Avatar
let me take a picture quickly... not hard to do. make two pieces of wood and nail them together
granted this is for a box with two sq10's but you get the point
