Wide Body Kits
Old Apr 10, 2008 | 10:37 PM
LilRedSciontC1's Avatar
Default Wide Body Kits
How do you put the fenders on????
Old Apr 10, 2008 | 10:43 PM
Scott8's Avatar
Default Re: Wide Body Kits
You usually have to mold them to the body. not easy to do, and if you take it to a body shop, it usually cost a lot
Old Apr 11, 2008 | 02:12 AM
davedavetC's Avatar
carefully....
Old Apr 11, 2008 | 03:29 AM
2_much_tc's Avatar
once you go widebody... there is no going back...
Old Apr 11, 2008 | 03:34 AM
bigwillystyle23's Avatar
2 sided tape and super glue and a couple of wood screws
Old Apr 11, 2008 | 03:36 AM
jk^ i loooooove widebodies
reminds me of that lil wayne song where he says
im in that widebody, imma need 2 lanes.
weezy is a lyrical genius
Old Apr 11, 2008 | 03:51 AM
2_much_tc's Avatar
i don't know about that... but i do like him in the song with Little Brother... What ya know about that? Those guys are lyrical geniuses...
Old Apr 11, 2008 | 06:39 PM
deflaytedwayz1's Avatar
There is a company called Lord fuser or DR fuser or something like that that has an excellent metal to fiberglass or plastic bonding agent. Then fiberglass it to fill the gap and give it the molded look. Or I guess you could go the cheap going to crack first time you take a corner route and use regular body filler. Either way it is a ____ load of work and if you haven't done it before or don't have the confidence that you can do it then take it to a pro because if you attempt and fall flat on your face they're going to charge you an a$$ load to fix it. There are companies that do make bolt on widebody kits if you want to go that route. Then you have to cut your stock fenders out so you can throw some 10" and 13" wheels under there. But then you might as well get a turbo and a cool ___ paint job and it's really a lot of work and money. Sorry for rambling on but I really want to do it and have absolutely no money so yeah I'm just a loser!
Old Apr 11, 2008 | 06:41 PM
2_much_tc's Avatar
^ loser no... dreamer yes...
Old Apr 11, 2008 | 07:31 PM
ryphlex's Avatar
Originally Posted by deflaytedwayz1
There is a company called Lord fuser or DR fuser or something like that that has an excellent metal to fiberglass or plastic bonding agent. Then fiberglass it to fill the gap and give it the molded look. Or I guess you could go the cheap going to crack first time you take a corner route and use regular body filler. Either way it is a poop load of work and if you haven't done it before or don't have the confidence that you can do it then take it to a pro because if you attempt and fall flat on your face they're going to charge you an a$$ load to fix it. There are companies that do make bolt on widebody kits if you want to go that route. Then you have to cut your stock fenders out so you can throw some 10" and 13" wheels under there. But then you might as well get a turbo and a cool butt paint job and it's really a lot of work and money. Sorry for rambling on but I really want to do it and have absolutely no money so yeah I'm just a loser!
You live in Concord? I'm there quite frequently.
Do you know any Asian girls with the last name Aquino?
Old Apr 11, 2008 | 08:22 PM
scandalous's Avatar
Scion Driven Girls
Like so....
(And, yes.. once you go wide, you don't go back. Your stock fenders are cut to accommodate the wider wheels)
Widebody Bolted On:
With Molding:
ALL DONE!
Old Apr 12, 2008 | 03:40 AM
Scoobasteve4132's Avatar
That car's freaking hot!!!... Hope whoever picks it up takes care of it...
Old Apr 12, 2008 | 04:30 AM
nebster's Avatar
figure to spend about 10-12k for a good molding job and prep then another 3-4k for paint.
15k for a good job then you'll need custom wheels so figure another 3k so with everything probably close to 20k . these are probably a bit high but not too far off
Old Apr 12, 2008 | 05:29 AM
scandalous's Avatar
Scion Driven Girls
^^ Nope, pretty accurate.
Old Apr 12, 2008 | 05:38 AM
1_kLEan_tC's Avatar
20k.....Damn that lot of cash. but its worth investment everytime you look the car....I know because I have about 15k and that the feeling I have.
Old Apr 12, 2008 | 06:19 AM
iKONA's Avatar
The thing about wide bodys is its easy to crack if your not careful. The right way to put them on is to first rivet or screw them together. Screwing is better because rivets can crack through the fiberglass. Then you grind the 2 sides down real well and deep and slash xxxxxxx along it so its like a stitch. Then you put fiberglass bondo over it, then put fiberglass mesh over the bondo when its wet. Let it dry, then put more fiberglass bondo over that and the mesh is the main thing that keeps it form moving around. Then the rest of it is making sure not to put stress on it so the fiberglass wont crack.
All that costs a few bills a side to have it done perfectly.
Old Apr 13, 2008 | 12:43 AM
Nick06tC's Avatar
The correct answer is, If you have to ask, you cant do it.
Obviously you cant do it yourself, because you had to ask. So logically your going to pay to have it done, and if your paying, it doesnt really matter how its done, because only your wallet is going to need to know.
Old Apr 13, 2008 | 01:53 AM
iKONA's Avatar
Ohhhh be nice now. We learn by asking :D
Old Apr 13, 2008 | 01:55 AM
nebster's Avatar
and learn by doing, but molding a widebody kit has a pretty steep learning curve
Old Apr 13, 2008 | 02:25 AM
silverstreaktc's Avatar
there was a place by me in fords, nj called DTC DESIGNS. they have been since closed down but they charged $1000 to mold on fenders.
