Rear Rotor Changing question
Old Apr 11, 2008 | 06:55 AM
Nightprowler09's Avatar
Default Rear Rotor Changing question
is changing the rear rotors on a tc the same as doing the fronts? I know theres a drum brake back there for the e brake does that come into play when changing the rear rotors or do the rotors actually slide over the drum?
Thanks for your time in advance.
-Mike
Old Apr 11, 2008 | 08:19 AM
datdude1119's Avatar
isnt it 4 wheel diskbrake , no drum?
Old Apr 11, 2008 | 03:32 PM
Sciontistical_One's Avatar
the inside (hat) of the rear disc serves as the drum for the e-brake.
Old Apr 11, 2008 | 04:27 PM
JL56TC's Avatar
yeah I changed mine and I didn't have to deal with the E-brake
Old Apr 11, 2008 | 04:30 PM
Default does it interfere with the rotor then?
so then if it's just the "hat" then the rotor should slide ride over it correct? So I shouldn't have to worry about anything to do with the e brake drum?
Old Apr 11, 2008 | 11:26 PM
tCeeder's Avatar
correct, but when working on the rear brakes (i.e. replacing the rotors), dont forget to take the e-brake off.
Old Apr 12, 2008 | 05:31 AM
i'm not sure i completely follow.... i've changed pads and rotors before on other cars however i've never had to deal with an ebrake setup before... what do you mean by disconnect the ebrake? is this a required step to change the rotor? If so can any one explain the process or have pics?
Old Apr 12, 2008 | 07:36 AM
bkuhl's Avatar
he means disengage the parking brake... if you leave it on you won't be able to remove the rotor...
Old Apr 12, 2008 | 11:54 AM
tCeeder's Avatar
x2.
the e-brake pads latch onto the inside of the rear rotors. if you leave the e-brake engaged and try to take the rotors off, you won't be able to.
Old Apr 12, 2008 | 11:55 AM
tCeeder's Avatar
...unless you're hulk
Old Apr 12, 2008 | 02:55 PM
lol well that makes sense.... so then theres only one pad per rear rotor for the regular brakes on the outside corrrect?
Thanks for the clarification guys I really appreciate your time.
Old Apr 12, 2008 | 08:09 PM
tCeeder's Avatar
no the rear calipers hold two pads per caliper just like the front.
Old Apr 16, 2008 | 01:57 PM
hustler900's Avatar
Rear should be just as easy as the front, as long as you remember to keep the parking brake off while your doing it. You will not have to mess with the small drum brake.
Ferretgrrl
Oct 15, 2018 02:50 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
torranosaurus
Jan 28, 2015 04:53 AM
mrsocks
Jan 20, 2015 01:29 PM
evolving_machine
Jan 13, 2015 08:04 PM
