Stock Air Filter Change
Pretty easy swap...
Unsnug the hose to make it easier for you.
There are two clips in the front of the box
Found this picture online actually...
Unclip those pull it towards you and up, pull your filter out and just place your new one in. I just got a K&N from my friend, calculated a gain in my MPG so I think it's worth it...
Just make sure to place the piece in the back correctly and clip the box back in and re-attach the hose and you're set.
Hope that helps!
Hope that helps!
Music City Scions
Originally Posted by Metro273
I just changed my OEM filter at 33K miles and wow! It was nasty! Good thing I changed it when I did...
Not a problem!
I recommend the K&N, while it cost a little more it is washable, you can clean it and re-use it, they also carry a one million mile warranty so if you were to run into some problems you'd be taken care of.
Music City Scions
By removing the snorkle and adding the drop in K&N I saw about 2 mpgs improvement. It adds up over time and even if you don't see improved mpgs, the money saved on buying throw away filters is enough to warrant the K&N purchase.
I'm saving my stock K&N for use when I go back to the stock intake. Right now I'm still using my YDR intake with a round K&N.
Mine improved by a min. of about 3mpg over the last year+ with this combo!
cid_mcdp
Jan 5, 2015 02:45 PM
Godfryness
Jan 2, 2015 11:18 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
