Premium HU SW RCA output issue
Old Apr 12, 2008 | 06:31 PM
generem's Avatar
Default Premium HU SW RCA output issue
Hi guys..
When I got my Sub + Amp installed, the shop said that when they plugged in the SW RCA to the back of the Premium Head Unit, there was no sound output. I checked for myself and there is no sound when using the SW rca jack. We had to splice the rear to get the SW working... Anyone else had this issue or have a fix?
Thanks
Old Apr 12, 2008 | 07:37 PM
06scioxb's Avatar
Team XcelsiA
Team Sushi
DID YOU TURN ON THE SETTING ON THE HEADUNIT
Old Apr 12, 2008 | 08:46 PM
miketf1's Avatar
turn off the head unit (with the PWR button no tricks here)
press and hold the MENU button and it will beep and a separate menu will pop up
turn the wheel and find the subwoofer tab and turn it on!
but i heard that the pre-outs have quite low voltage output but that can be easily solved with gains settings on the amp
Old Apr 12, 2008 | 08:55 PM
Slody4Futbol's Avatar
Directions FTW!
Old Apr 13, 2008 | 12:47 AM
jimmbomb's Avatar
Yes... Now take it back to the shop & have 'em re-hook up those SW RCA jacks.. Those Line level outs to your amp just wont do.......... I mean they will, in a pinch , but,... just you'll see the difference when you switch back to the SW RCA's!!! 50X better!!!! goood luck..... jh
Old Apr 13, 2008 | 01:21 AM
generem's Avatar
Followed miketf1's instructions and did the switch to the rca jack myself.. WOW... much better..
Thanks....
Wished I've could of done the install but I dont have the tools, or a place to perfrom any type of work automotive work...
Thanks...
Old Apr 13, 2008 | 01:40 AM
jimmbomb's Avatar
Thanks....
Thanks...
Good job!!! yeah... all you need is one phillips screwdriver to get your stereo out of there & into your lap!!!! jh
PS.. let's see pictures of your SUB & amp set-up installed!!!!
Old Apr 13, 2008 | 01:59 AM
miketf1's Avatar
Thanks....
Thanks...
well i could have been a dick and just told you to read the f*ing manual but thats not what this community is about!
but by your description you do kinda have a line-out converter behind your head unit taking up space and creating excess heat. if you dont have any tools you should take it to a proper shop so that they can remove it and tape up all the wires so there isnt any fire hazard!
Old Apr 13, 2008 | 02:12 AM
generem's Avatar
thnx for not being a dick
sciontcguy15912
Mar 27, 2015 09:06 PM
ScionLife Editor
Dec 6, 2014 11:58 PM
JonathonK
Dec 6, 2014 12:13 AM
ScionChick
Feb 19, 2004 02:27 AM
TJ
27
Feb 8, 2004 12:20 AM
