rim width?
Old Apr 13, 2008 | 02:08 AM
natecis's Avatar
Default rim width?
I have looked at all the rubbing charts on this site and was just wondering if anyone out there has 18 x 8.5 rims on there car lowered with no rubbing if so exactly what brand and size rim and tire, offset and inches lowered. I thank you in advance for your time on this.
Old Apr 13, 2008 | 02:12 AM
Higgy's Avatar
I have 18x8 on s-techs with no problem at all. I know its not what you asked but its close so I figure Id lend you my input.
Old Apr 14, 2008 | 09:30 PM
Leo_EdgeRacing's Avatar
18x8.5 ET 35 with 225/40R18 Falken FK452. Dropped on Tanabe DF210 about 2".
It will rub on full lock turns and some speed bumps. Not a real concern.
Old Apr 19, 2008 | 02:44 AM
graphite06's Avatar
where does it rub? the fenders or the wheel tubs?
Old Apr 19, 2008 | 02:58 AM
austinguy83's Avatar
are your fenders rolled? That fitment is HOT.
Old Apr 19, 2008 | 03:19 AM
Xero187's Avatar
Nice rim choice! Your the only other bsp I've seen with those.
Man that white tC is cleaning looking! The drop & rim choice are working well, very well!
The rubbing is more dependent upon the offset (ET) and the tire width rather than rim width.
7" 205-225
7.5" 215-235
8.0" 225-245
The idea is you don't want to stretch the tire too much or have it bulge too much either.
The tC on a moderate drop accomodates up to a 225 wide tire very easily as long as the rim offset isn't lower than ET42mm
I'm having issues with my current set up, however before when I had 225/40R18x7.5 ET45 on a hotchkis drop I had Zero issues even under hard turning while braking.
Again the key is wheel size & offset. Also, make sure you keep the wheel diameter the same, that way you dont offset the speedo too bad & the tire is kept at the same circumference as stock.
My current set up with issue is the 18x8 ET45 DC6 V2 Tenzo's that Higgy's sporting but wrapped in 245/35R18 on a year old Hotchkis drop ( I swear these bastards have settled past 1.7F/1.9R ).
EdNog over at ystc is real knowledgable on the subject. here's link with a very useful tire size fitment chart on the first page of the thread.
http://www.yoursciontc.com/forums/in...howtopic=15091
To recap:
If you'd like to run an 18x8.5 make sure it is ET42 - ET48 , wrap them in a 225/40R18 size tire, and drop it with H-Techs, Hotckis, TRD, or anything else of similar specs and you'll be fine!
current set up:
Old Apr 19, 2008 | 04:02 AM
Higgy's Avatar
I think somebody else on here might have the same wheels on another BSP. I like them and get alot of compliments. Cars looking good.
Old Apr 21, 2008 | 06:59 AM
xxsoysaucexx's Avatar
im planing on getting 18x8 with a 35 offset and im on stechs will that rub a lot??
Old Apr 21, 2008 | 04:41 PM
Xero187's Avatar
what size tire? 225 should be fine, 235 & 245 not so much!
Old Apr 21, 2008 | 05:21 PM
natecis's Avatar
The wheels I want are 18 x 8.5 with a offset of 35, just like austinguy's. He has 225/40/18 and says it rubs a little on a 2" drop. I am getting the rs1 lip kit with the HKS hypermax rs coilovers on about a 1" - 1 1/2" drop I am assuming I would have less rub than him if any at all and I figure with the hypermax's 30 position dampening I could stiffen it or adjust the drop to get it to not rub at all what do you guys think. Xero why do you say use an offset of 42 - 48 when austinguy has a 18 x 8.5 set up and his offset is 35. I'm new to buying rims is there any way to adjust the offset on a set of rims that only come in one offset like most rims do, cause like I was saying the ones I want come in only 18 x 8.5 with a 35 offset in my bolt pattern. Any ides?
Old Apr 21, 2008 | 08:36 PM
It rubs a bit on bumps and locked turns and only on the fender.
Nope.
Old Apr 21, 2008 | 08:38 PM
You'll be fine with that size.
Old Apr 21, 2008 | 08:46 PM
current set up:
[/quote]
Xero187,
Now thats looking sexy. Jajaja. Thanks for the compliment, but thats my friends ride.
This one is mine:
18x7.5 ET35
Old Apr 21, 2008 | 09:17 PM
natecis's Avatar
Thanks and my bad thats was Leo's ride and wheel fitment not austin I messed up.
Old Apr 22, 2008 | 02:20 AM
would i have to roll the fenders cause rite now i have 18x7.5 and it rubs if im going fast and turning
Old Apr 22, 2008 | 03:15 AM
Xero187's Avatar
When looking for an offset between 42 & 48mm on a 18x8 or 18x8.5 @ 5x100 the selection sucks big time. I don't know why that is, but it just does.
I believe stock offset is 45mm.
If you go for a 35mm you are now 1cm (10mm) closer to the outer fender wall. Upgrade to a 225mm tire with 35ET and you are now 1.5cm closer to the fender wall.
Upgrade to a 245mm tire and you are now 2.5cm closer to the fender wall and it will rub & require rolling the fenders.
Right now I'm at 45ET with a 245, so I am 1.5cm closer to the fender wall and it is tight, real tight.
Old Apr 22, 2008 | 03:23 AM
Xero187's Avatar
Natecis, Just don't plan on going any wider than 225's with an offset of 35.
I'd really recommend trying to find a rim with a 45 offset, so you have room to grow.
Don't forget the hubcentric rings either!
The hub bore for the tC is 54.1mm
Old Apr 22, 2008 | 03:57 PM
What offset?
Old Apr 22, 2008 | 05:46 PM
HKSpeed's Avatar
you'll have comprimise your driving style and ride height if you dont want to rub. i think 18x8.5 et35 will fit fine on a 1.5" drop. you'll occasionally rub but thats to be expected. its like saying "I want lower my car but not scrape against anything", which is unreasonable to expect. luckily you'll have coilovers, so it'll be a trial and error thing to find the best height and dampening settings to suite your needs. i highly recommend Falken Ziex 512 or Toyo Proxes 4 tires which stretch really well and dont have large sidewall bolsters, which will minimize rubbing. Nanking and Visa tires also stretch well for budget tires.
