DEI Tilt Sensor Problem
Old Apr 14, 2008 | 11:13 PM
ricexizxgood's Avatar
Default DEI Tilt Sensor Problem
Hey,
I just installed the DEI 507m tilt sensor to my Viper 791xv alarm, but its not working. Can anyone tell me if I did it wrong? I connected the red, blue and orange wires from the tilt sensor to the red, blue and orange wires on the main alarm harness.
Thanks
Old Apr 15, 2008 | 04:02 AM
tweetertc's Avatar
which wire on the brain did you hook them up to... cause they dont have direct inputs for it...
Old Apr 15, 2008 | 08:01 AM
I connected the red (+ constant power) from the sensor to the brain's red (+ constant power input). The orange (- turn-on input) from the sensor to the brain's orange (- 500mA armed output). The blue (- trigger output) from the sensor to the brain's blue (- multiplexed input, zone 4). All of the wires were on the primary harness of the alarm's brain.
Old Apr 15, 2008 | 10:10 PM
tweetertc's Avatar
ok ok... check your wires at the tilt sensor itself... make sure your getting 12 volts at the plug... and when you arm the alarm your getting ground... then if you are... tilt the sensor ever so slightly and see if your getting a ground back out of it....
thats a good place to start...
Old Apr 16, 2008 | 09:23 PM
Hey I got it to work! I found out that the power wire wasn't connected cause the t-tap didn't connect to one of the wires.
Thanks
Old Apr 16, 2008 | 10:47 PM
2_much_tc's Avatar
you installed this alarm yourself?
Old Apr 16, 2008 | 10:58 PM
Nope, I had a buddy install the alarm for me.
Old Apr 17, 2008 | 04:24 PM
combatsteve's Avatar
Thanks
eww t-taps
solder your wires
Old Apr 17, 2008 | 04:37 PM
tweetertc's Avatar
Thanks
eww t-taps
solder your wires
X2
nightfox915
Apr 17, 2015 07:06 PM
xa007xa
Feb 22, 2015 03:05 PM
lunchbx05
Dec 11, 2014 06:13 PM
hotroddelux
Dec 3, 2014 11:33 PM
scionspecialistvegas
Dec 15, 2003 11:21 AM
