quick vrd installation question
Old Apr 20, 2008 | 06:09 AM
scv2004's Avatar
Default quick vrd installation question
I am kind of disappointed that the thread VRD started on their fog lights no longer displays the pics for the install. I am wondering how difficult it is to install.
And on a second note, do the lights turn on/off with the headlights are parking lights or do you have a choice?
Thanks!
Old Apr 20, 2008 | 06:24 AM
O5_TRD_tC's Avatar
didn't it come with instructions?
no u dont have a choice, your headlights must be on. There is a mod around it though.
Old Apr 20, 2008 | 06:28 AM
SquallLHeart's Avatar
it's easy to install... it only gets slightly more difficult with a lip kit as you'll just need to do some additional work (cutting)
but other then that.. everything is just pretty much plug n' play.
Old Apr 20, 2008 | 06:34 AM
tCtCtC's Avatar
took 30 minutes to install mine
Old Apr 20, 2008 | 06:46 AM
scv2004's Avatar
I am getting my jp vizage kit installed soon, that still shouldnt be a problem right?
Old Apr 30, 2008 | 04:05 AM
scv2004's Avatar
do the instructions that come with them explain how to plug everything in??
Old Apr 30, 2008 | 04:48 AM
CaptonTypo's Avatar
TRDsparks has a PDF for the installation of the stock fog lights. From what I understand (someone correct me if I'm wrong) it should be the same, but just with the equipment you receive from VRD.
Here is the link.
http://www.trdsparks.com/install/PT413-21050inst.pdf
Hope this helps.
-CT
Old Apr 30, 2008 | 06:06 AM
bsptcftw's Avatar
Yeah I just installed these last weekend. Download that pdf and it pretty much follows the same install. The only time-consuming part is removing the front bumper and putting it back on but otherwise it's plug and play.
Old Apr 30, 2008 | 05:22 PM
nano's Avatar
I installed mine a couple weeks ago without removing the bumper. It took me a long time ( >1 hour) because I'm pretty much a complete car newb and it took me forever to get the cover thing under the engine off. Other than that, it was surprisingly easy.
Old May 1, 2008 | 02:33 PM
tkevin07's Avatar
there is a way to wire it to allow the fog lights to come on independently i did it and it works here the link
https://www.scionlife.com/forums/viewtopic.php?t=185730
just follow the pics basically the gray wire is the relay's power to control the magnet
Old May 3, 2008 | 08:41 PM
Farcus001's Avatar
How difficult was it to install the VRD without removing bumper? I'm planning to order the vrd from ebay and i really don't want to remove any bumper.
Old May 5, 2008 | 04:34 PM
tkevin07's Avatar
you shouldnt have to remove the bumper its basically the fender liners but only the front half of it, if u look under ur car and right behind where the fog lightss are u just need to take that part off, its only 5 screws
Old May 5, 2008 | 04:42 PM
Dilirious's Avatar
well i took of the bumper so i could route the wires and firmly tie em up to the engine wire harness its not even that hard though.
Old May 5, 2008 | 05:46 PM
nano's Avatar
Only hard part is what tkevin07 said, removing the fender liners, which still isn't that hard.
Old May 7, 2008 | 12:17 AM
Farcus001's Avatar
what is fender liners =o
so I don't have to take the bumper off right thats all I really need to know.
Old May 7, 2008 | 12:22 AM
a_german_named_hans's Avatar
i used the OEM fog light install guide to install my VRDs.
https://www.scionlife.com/forums/viewtopic.php?t=27616
That's the topic I used. Its basically the same exact procedure, same steps plugs everything. Only thing different is the location of the lights. and obviously you don't have to remove the grill. I actually removed my front bumper, found it easier to work like that.
Front bumper is cake to take off. I did it in a few min. One bolt behind the fender liner, One on it. One under the corner, then like 5 out front, other side is the same as the first. couple push plug thingies up top and it just pops straight back.
Old May 19, 2008 | 03:42 PM
Farcus001's Avatar
If i take it to an autoshop would they be able to install for it?
Old May 19, 2008 | 03:47 PM
optional's Avatar
huge waste of money... but yeah i guess...
Old May 19, 2008 | 03:48 PM
BLUEMEANIE's Avatar
Team Hamster
If you can take the vent panels out you can install the VRD fogs. I did mine in about 10 min.
Old May 19, 2008 | 04:16 PM
Farcus001's Avatar
well its the electrical part that I don't get
