Post your range!
Old Apr 21, 2008 | 08:16 PM
Invertalon's Avatar
Default Post your range!
Instead of MPG, lets see what you all are getting as far as range is concerned.
This is the highest range I have ever had, got it at my last fillup.
I wonder if anybody has gotten it to 375+? Be insane!
Old Apr 21, 2008 | 09:23 PM
Mario3030's Avatar
prior to putting my current wheels on i would get 356 mi in the range. After putting my current wheels on the best range i've got was 340 mi.
Old Apr 21, 2008 | 09:48 PM
randomsuper's Avatar
i hate you guys. i'm getting right around 250.
Old Apr 21, 2008 | 10:58 PM
pinkysbox's Avatar
My supposed range hit 303 after todays fill.
Old Apr 22, 2008 | 02:24 AM
714xb's Avatar
Is range calculated based upon your avg mpg?? If so no wonder i only get 275 miles on my range after fill up.
Old Apr 22, 2008 | 03:35 AM
ravenfox's Avatar
How are you guys getting 375? I only have like 500 miles on my xB2 and my range is right around 275..average MPG is 28 combined..Also, is the range including the reserve? Because I had like 1/4 tank left and a 56 mile range before fill up and that didnt seem right.. I realize the mileage will get better over time..but 275 range is pretty bad.. AJ
Old Apr 22, 2008 | 04:01 AM
MaxBoost925's Avatar
How do you set the range? I don't think it resets if you hold the button.
Old Apr 22, 2008 | 04:27 AM
Invertalon's Avatar
You don't reset range. Range is the approximation made by the cars computer that basically gives you an estimate of how many miles until you should fill-up.
Usually when it does hit zero, you only put about 12 gallons in, out of the 14 gallon tank.
Also, range is "learned" in a way. So with only 500 miles on your xB, the computer is still "learning". My range JUST got back up to level I am at since I installed my HID's (in which I had to disconnect the battery, which reset the ECU). So slowly it "relearned" my driving habits or whatever and fuel/air mixture to give me the range im getting.
With more miles your range should increase, if you dont drive with a lead foot.
Old Apr 22, 2008 | 04:42 AM
SiZzOuRcE's Avatar
I fill up 11.2-11.5 gallons and get max 230miles to the tank.
I have never gone above 11.5 gallons when filling up. Your talking about filling up 12 gallons out of a 14 gallon tank? Either every gas station around S. Florida is wrong or my tank is a 12 gallon tank.
I can't seem to understand why I am only getting 20mpg every tank and I see alot of people here getting 28mpg and having a range of 300+ miles to the tank. Is there something wrong with S. Florida because I noticed the same thing when I had my truck; people were getting better MPG and the only change was the State/Area.
I only have around 2500 miles on my xB as well and I do around 25% highway (at or around 80MPH) and 75% city driving.
Old Apr 22, 2008 | 05:01 AM
Invertalon's Avatar
Our light comes on premature. When my light comes on I usually will fillup to 11.4 gallons, usually always right around there.
Our tank IS 14 gallons. Let the range hit zero and and know you can drive a bit on it. Just don't push it ;)
But really, you don't need to worry about filling up until your range does hit ZERO. You wont run out of gas, you still have like two gallons left at that point.
Old Apr 22, 2008 | 05:09 AM
SiZzOuRcE's Avatar
Your probably right, however regardless of how long I go before filling up, I still average 20mpg.
Very strange.
Old Apr 22, 2008 | 04:02 PM
Invertalon's Avatar
How are your driving habits?
I am not really a "grandma" driver by any means, but I do use cruise anytime I can, coast to red lights, and really try to look ahead to what im doing. In reality, anytime you use the brake your wasting gas so I try to avoid it anytime I can.
I also do alot of highway driving, which is why my mileage is probably higher. My normal routine probably consists of 40% city, 60% highway, roughly.
Old Apr 22, 2008 | 04:56 PM
SiZzOuRcE's Avatar
Yea, I barely drive the freeway at all. Only about 15-25% max.
Here is FL, the lights are very close together along with high speed limits (around 45mph, I usually do around 50-55mph) and congested roads, I am constantly on my brakes with stop and go, stop and go, stop and go.
Old Apr 28, 2008 | 06:17 PM
Invertalon's Avatar
Just filled up the other day and got an even higher range... 370!
Old Apr 28, 2008 | 08:50 PM
borninussr's Avatar
PHOTOSHOPPED!
Old Apr 28, 2008 | 09:05 PM
Jan06xB's Avatar
Guess what . . . your brakes don't put gas back in the gas tank!
Feel how hot your wheels are after a typical ride and you will know where all the gas is going.
Old Apr 29, 2008 | 12:57 PM
alfundo's Avatar
Lehigh Valley Scions
The stations up here in the northeast just switched back to summer gas...as a result my mpg just shot up %10. i haven't checked the range tho.
Old Apr 29, 2008 | 07:18 PM
nameless_ak's Avatar
hey invertalon what does it say your mpg is? last time i filled up it said 350 which is not the best i've had
Old Apr 29, 2008 | 07:38 PM
Invertalon's Avatar
I have averaged the past seven fillups at 29MPG.
My last two tanks I got 30MPG (done manually), the computer usually shows like 32 or so. Its about two over always.
Old Apr 29, 2008 | 11:01 PM
kidd's Avatar
you drove almost a thousand miles in a week?
