Will Aftermarket Seats Mess airbags Up?
Old Apr 23, 2008 | 03:23 AM
SVicksTC's Avatar
Default Will Aftermarket Seats Mess airbags Up?
Hey i just ordered some after market seats for the TC and i didnt take in account that he airbag sensor is under the seat....If i take the seats out will the airbags not go off in the even of an accident being its not registering in the sensor?
ANy info would help thank you!!!!!!!!!!
Old Apr 23, 2008 | 03:55 AM
nebster's Avatar
yes
you're f'd
Old Apr 23, 2008 | 04:47 AM
BZinn1's Avatar
Pretty much you need to remove the sensors from the stock seats and put them in the new seats.......to do this you need to remove the seat covers and you will find them........mount them to new seats in same general locations and the airbags will work......if you have the seat side airbag that will not work but it can be placed at the feet area of the back of the new seat so it is out of the way should it go off.....
Old Apr 23, 2008 | 06:02 AM
SVicksTC's Avatar
alright thanks for the info...is this hard to do?
Old Apr 23, 2008 | 06:12 AM
equinox2355's Avatar
WOW! That is SO unsafe! If you have the side airbags, you will need to have resistors for the connector, so that you dont get the airbag light.
I dont know about you, but I wouldnt want HIGH EXPLOSIVES just laying around behind my seat like that when it isnt where its engineered to be!
Old Apr 23, 2008 | 06:22 AM
SVicksTC's Avatar
I dont have the side airbag seats, just the regular ones so im not worried about that.....Just is locating the under the seat on and trasnfering hard?
Old Apr 23, 2008 | 06:26 AM
I never have tried, but will be soon. I was just pointing out what HE said there, not about what you were talking about. I didnt want to let people get the idea (the ones with the side air bags) that you can just leave LIVE airbags hooked up and in the back seat.
Good luck with the transfer, and let us know and post pics!
Old Apr 23, 2008 | 06:28 AM
SVicksTC's Avatar
i kinda figured thats what you were doing but pointing out to others and you for futher information,.....Thanks Thouhg and def will post pics
Old Apr 23, 2008 | 02:14 PM
BZinn1's Avatar
Since you do not have airbag in the seat all that you need to do is transfer the pieces that the wires plug into that are attached to the frame to the new frame tot he same general location and plug them in to the wires coming from floor board.....
Just finished doing seat transfer two weeks ago and no airbag lights and seats know if there is a person too small there as well...........yes putting the airbag behind base of seat is not the best idea.........sorry to offend you equinox.........but you do not need to be rude and call me a loser........if you have a better way to solve the problem then post it so the person can use it.......
Old Apr 23, 2008 | 04:04 PM
yellowxhoodie's Avatar
damn, i gotta do this soon to when i install my sparcos.
Old Apr 23, 2008 | 05:20 PM
so anybody else have any advice or info that will make install of aftermarket seats easier?
Old Apr 23, 2008 | 07:00 PM
SVicksTC's Avatar
thanks for all the info, do you know of any little tricks to make things easie?
Old Apr 24, 2008 | 04:22 PM
I was "rude" because it is extremely unsafe.
Now to bypass all that is needed are resistors, and sadly I don't know the resistance, but I would believe it would be between 2Ohm and 5Ohm, but probably would be closer to 5Ohm.
Old Apr 24, 2008 | 08:23 PM
trialsindude's Avatar
Strictly Scionized
5ohms per yellow plug
Old Apr 24, 2008 | 08:24 PM
Thanks for the confirmation, I figured it would be close to 5Ohms and it was actually 5Ohms. Had you replaced the seats in your car?
Old Apr 24, 2008 | 08:43 PM
wow, this whole aftermarket seat thing looks like its gonna be way more complicated than i thought.
Old Apr 24, 2008 | 09:19 PM
Strictly Scionized
I have a set of Corbeau in and for the airbag plug i have 2 10ohm wired in parallel to get 5ohms in each plug. No airbag light for a year already.
I also pulled out the black box that is on the driver seat and stuck it on the new seat. The passenger seat sensor I pulled that out and zip tie it to make it seems like someone is sitting in seat all the time.
Old Apr 24, 2008 | 09:26 PM
Sweet, thanks for the input, I really appreciate it
Old Jul 16, 2008 | 05:57 AM
fujita_TC's Avatar
ok wait...i ahve a problem i put some corbeau cr1s and my light is on.... me and ryphlex did a straight trade for my stocks and thought the reason why my air bag light is on because i have 06 seat belts on mine...does the year matter? or no differences in seat belts...
so i checked again this morning and everything is plugged but on the passenger side theres the big black plug just hanging around with nothing to plug into...and thought thats the reason why my airbag light is on.... where does that plug into??
so the question is...
1. are the 06/07 seat belts different?
2. what does the black plug on the passenger seat plug into..
3 and what are you guys talking about the resistors...
Risen_Son_Racing
May 6, 2005 02:31 PM
joedjin
31
Feb 7, 2004 03:25 AM
Docsnuff
Dec 24, 2003 12:41 AM
