i need chamber kits foy my Tc
i dont think youll need these unless you did a major drop on it but heres a place i found some
http://www.hopupracing.com/hosctc05reca.html
"Delrin and self-lubricating Bronze are used in the main-body bushing, replacing the squishy stock unit for better control of your camber, caster, toe, and arc movements"
Something I'm investigating.
are you sure they will installed correctly?
2"/1.5" is a lot different from the 1.4"/1.3" that H&R quotes. just asking cause i had a similar problem on my old teg and ends up my cousin installed the fronts in back and backs in front.
if you find out this was the case and you get it fixed, hook me up with some pics. i'm thinking about the H&R's myself. thanks and good luck homie.
You might want to try adjusting the camber first. Unlike most McWorthless strut cars, the tC has adjustable camber on both ends of the car. You might be able to pull out a degree and half just using the OEM adjustments.
daewonder, there is no way you could put them on backwards ,the spring from a strut and the spring from a coilover are very different in size, and the h&r scion tc oe sport spring is rated by h&r at 1.4/f 1.3/r depending on the application, and how much your stock springs have already sagged. since my springs were still new i got a very nice drop out of them, and then they settled even more giveing me 2 in the front and a litlle over 1.5 out back it .it looks sick with the 18s and i will post you a pic as soon as i get the new usb cord for my camera
thanks for the tip lo bux!
NonStopTuning
Jun 29, 2015 07:42 PM
my06tc
Jun 25, 2015 12:18 AM
umnitza
Dec 1, 2014 06:26 PM
