#74 LED Doesn't Fit in Holder ?!?
Old Apr 24, 2008 | 04:15 PM
ChrisLilja's Avatar
Default #74 LED Doesn't Fit in Holder ?!?
So I bought a #74 Mini Wedge Base Blue LED from superbrightleds.com, and the base of the bulb does not fit into the "bulb holder" in the Auto Shifter piece. I was able to get the same exact bulb into the cubby hole holder, but for whatever reason the holder on the Auto Shifter piece doesn't accept the LED. It kind of just rests there and makes contact but does not go all the way in and "click" it seems as if the base is a bit too big.... Should I shave a bit of the inside of the holder down or what?
Old Apr 24, 2008 | 10:27 PM
ChrisLilja's Avatar
...any ideas?
Old Apr 24, 2008 | 10:29 PM
CSOCSO's Avatar
i have the same LED>. it fits for me... so i dont know what is the problem there...
Old Apr 25, 2008 | 04:17 AM
ChrisLilja's Avatar
did u have to force it? I tried that.....
Old Apr 25, 2008 | 04:30 AM
CSOCSO's Avatar
no it was easy to install it..
wait.. u bought this one:
74-xHP Wedge Base LED Bulb
High power SMD LED with wide beam angle - 6 lumen
Small Wedge Base LED bulb (74 type) 3/16 inch wide base, 3/4 inch overall length
Select LED Color
$ 2.49
i think i bought this one:
74-x Wedge Base LED bulb
Small Wedge Base LED bulb (74 type)~ 2 lumen
3/16 inch wide base, 13/16 inch overall length
Flat tipped LED produces wide beam angle
Select LED Color
$ 1.19
so u might have to order the other one what i got...
oh one thing.. u could try this too
74-WHP3 Wedge Base LED bulb
3 High power White SMD LEDs with wide beam angle radially mounted - 15 lumen
$ 3.49
--- if u can pls get one of the 74-x Wedge Base LED bulb and of the 74-WHP3 Wedge Base LED bulb
and do a comparo/ write up.. THX!
Old Apr 25, 2008 | 04:38 AM
ChrisLilja's Avatar
Ok I will get in contact with superbrightleds.com and see what I can do - Thanks for your help
Old Apr 25, 2008 | 05:05 AM
CSOCSO's Avatar
np
XB06
May 30, 2015 02:42 AM
TheTripleC
Jan 4, 2015 06:46 PM
tc_Jake
Dec 31, 2014 01:45 AM
LVXB
20
Sep 24, 2007 07:07 AM
