joluis
04-30-2008, 02:06 AM
i just wanted to ask what is the huge tank on the exhaust in the middle of the car? and also is the cat connected to the exhaust manifold in front of the engine? thanks
View Full Version : exhaust question joluis 04-30-2008, 02:06 AM i just wanted to ask what is the huge tank on the exhaust in the middle of the car? and also is the cat connected to the exhaust manifold in front of the engine? thanks draxcaliber 04-30-2008, 02:08 AM that huge tank on the exhaust in the middle of the car is probably your resonator, it helps quiet down the exhaust noise. and since the xb is alot like the tc, i would imagine that the primary catalytic convertor is in the exhaust manifold collector. joluis 04-30-2008, 02:14 AM so thats what alot of people remove when they do a custom exhaust draxcaliber 04-30-2008, 02:18 AM no, resonators don't hurt performance, catalytic convertors and narrow piping does. if you just did straight pipes out of your xb, it would sound like $h!t, and drive you crazy. when you do custom exhaust, on a street car, you usually want high performance, but a tolerable (preferably enjoyable) exhaust note. so you would replace it all with piping that would have greater diameter for higher flow of exhaust gases. Aroddalobster 04-30-2008, 02:18 AM you're probably thinking of a cat converter joluis 04-30-2008, 02:22 AM ok thanks DAILYXB-TYPE-R 04-30-2008, 05:49 AM what would be an ideal diameter for the full piping? 2"1/4, 2"1/2, 3" Aroddalobster 04-30-2008, 05:52 AM 2.5 probably. 3 is for turboed, 2.25 is pretty much stock. draxcaliber 04-30-2008, 05:55 AM the diameter on the piping depends on the applications, n/a engines don't wnat exhaust that is too big, and f/i cars will want larger exhaust piping for minimalized back pressure. joluis 05-03-2008, 09:03 PM ok i have another question, im gonna get one of these but i want to know what is the difference in the size of the oval? or it doesnt matter the both will sounds the same 4x9 oval http://cgi.ebay.com/ebaymotors/MagnaFlow-Muffler-4-x-9-Oval-14-Body-2-25-C-C-11215_W0QQitemZ220229583215QQcmdZViewItem?hash=item220229583215& 5x8 oval http://cgi.ebay.com/ebaymotors/2-25-C-C-5x8-Oval-14-Body-MagnaFlow-Muffler-SS-12215_W0QQitemZ380015815991QQcmdZViewItem coryjames 05-03-2008, 10:55 PM there is a big cat in that resonator SiZzOuRcE 05-04-2008, 01:28 AM The scuba tank is a muffler. Not a resonator. Your only resonator is connected to the axel back on your car. For some reason, Scion decided to put the muffler mid car and the resonator behind it. That is why if you were to take off your axel back, your exhaust note would sound pretty good. This is due to the fact that you still have a muffler, but removed the resonator. The small piping in our cars is nice because it gives us plenty of bottem end power which is nice for the majority of our performance setups. Coryjames, I don't believe there is cat in our mufflers. It should be before that large muffler on the or close to the S pipe. coryjames 05-04-2008, 03:52 PM its built into the mid car resonator and a muffler is a resonator just the proper term for it |
