Fog lights?
Old Nov 30, 2004 | 08:20 PM
SMUTZ2K's Avatar
Default Fog lights?
Noob ?: Anyone have any reccomendations on fog lights for the xA Release 1.0? I would like to use them on my very stock xA (the holes are in the grill already), but am looking for opinions/examples from people that have them already. Thanks!
-Aaron-
P.S. Are their any headlight/taillight kits (HID or similar) for the xA?
Old Nov 30, 2004 | 08:41 PM
Tamago's Avatar
i have Hella Optilux 2500's.. a bit of a squeeze, but they're the best damn driving lights i've ever used.
do a search.. this has been covered
Old Dec 1, 2004 | 01:36 PM
Epitrochoid's Avatar
I got the factory kit from Spark's Scion (ask for Ken) for $218. The kit comes with the wire harness, relay and switch. It main harness is already there so it just plugs in.
However, I want my fogs to be independent of the headlights so I'm looking to get them wired differently.
HTH
Old Dec 1, 2004 | 01:53 PM
matt_a's Avatar
Define, "A bit of a sqeeze". Did you have to cut or modify the holes at all (besides the back part)? How hard were they to install? Got pics?
Old Dec 1, 2004 | 03:37 PM
Tamago's Avatar
if you want to wire the fogs independantly, just tap into the hot supply line for the harness and power it off a different source.
oh, as far as "bit of a squeeze" you do have to trim some of the rubber inside the bumper area. not visible from the outside. the lights are maybe 1/8" too large to fit the holes, but i built aluminum "brackets" to hold them into place very securely.
i only have pictures of them installed.
Old Dec 1, 2004 | 04:32 PM
SMUTZ2K's Avatar
Default Nice...
Thanks for the help everyone! I would like the foglights to be independant of the main's as well...any specifics/sites/guides you have on tapping the power for this? The cutting and mounting part is not the problem, but as for electrical, that's a whole other ballgame. Thanks!
-Aaron-
Old Dec 1, 2004 | 05:10 PM
Tamago's Avatar
find a good + source under the dash. i used a test light and found a wire that was hot with the ignition switch in the ON position, but not hot when ign = off.
then use that as your source. i can't really explain it any easier.. there are some blanks in the fuse panel that have this power source.
Old Dec 1, 2004 | 10:22 PM
tdivegas's Avatar
I just ordered those lights after seeing yours. I found them for $49.95 from Autobarn.com
They should be here by Friday.
Old Dec 2, 2004 | 12:28 AM
matt_a's Avatar
I'm sure I could come up with a way to secure those into place, but aiming them and keeping them aimed will be another issue. How did you do that?
Old Dec 2, 2004 | 12:43 AM
OK, I just took a look at the wires. Which one is the "hot" wire that I should move the the new power source? There are 4 wires that go into the switch.
Thanks!
Old Dec 2, 2004 | 02:07 AM
djct_watt's Avatar
Team Sushi
the hot wire is more than meets the eye
Old Dec 2, 2004 | 02:15 AM
Hahaha! Obviously you're a DecptaScion! :D
Old Dec 2, 2004 | 11:26 PM
Thanks!
Can someone PLEASE tell which wire is the "hot" wire???
Old Dec 3, 2004 | 06:32 AM
MrFord's Avatar
Default Control / Switch?
CivicEater: how do those lights work?
Is there a switch setting to turn on the "Angel Eye" part, then the main bulb separately?
Or does the Angel Eye turn on with the headlights - like a BMW's?
Thanks!
Trevor.
Old Dec 3, 2004 | 01:15 PM
Tamago's Avatar
it's a 3 way rocker.. one for angel eye, one for the actual bulb.
Epitrochoid you may have to do some testing of your own.. remember, it's only 2 wires to power the fogs, a + and a ground. honestly, all that other wiring is a waste, unless you want to hook into the stock harness.
Old Dec 3, 2004 | 01:27 PM
I used the stock wire harness. There are 5 wires going into the relay. I guess I'll just have to figure out which one is the hot wire and move it.
Old Dec 3, 2004 | 11:51 PM
djct_watt's Avatar
Team Sushi
I dunno which one is which. . . you could always use a multimeter
Old Dec 4, 2004 | 12:13 AM
I guess it's time I buy one, huh.
Old Dec 4, 2004 | 12:15 AM
djct_watt's Avatar
Team Sushi
hehehehe. . . they do come in handy if you work on your car's electronics often. You could try asking the Toyota Parts dept?
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
carid
Jan 8, 2015 11:33 AM
tc_Jake
Dec 31, 2014 01:45 AM
