Question On Hatch Shocks
Old May 10, 2008 | 03:08 AM
STNC's Avatar
Default Question On Hatch Shocks
Does anyone know of stronger/aftermarket shocks that will hold more weight than the original ones on the hatch? I need some that can hold more than 6 pounds. I did a test using two three-pound dumbells, and it held the first one, but when i put the second one on, it didnt hold... So i need a better shock!
Any Help/Suggestions?
Old May 10, 2008 | 03:23 AM
draxcaliber's Avatar
yeah, trd sparks sells heavy duty struts that are for the pedestul spoiler that scion makes for it.
http://www.trdsparks.com/displaypart...&parts_id=1070
Old May 10, 2008 | 03:32 AM
STNC's Avatar
AWESOME!
Old May 10, 2008 | 09:28 AM
SquallLHeart's Avatar
i have a set of those... they are quite a bit stronger thant he stock ones...
why do you need to have stronger ones anyway? 6 lbs..?
Old May 10, 2008 | 02:22 PM
STNC's Avatar
Something Secret...check your pm
Old May 10, 2008 | 02:26 PM
STNC's Avatar
How easy is the replacement?
Old May 10, 2008 | 04:26 PM
Dilirious's Avatar
really easy, make sure you have two people when doing this or your going to kill your self when that hatch drops. Basically the part where the strut connects to the hatch there will be a clip that holds it in take a flat head screw driver and pry it off. Once that is off you just pull it off the ball screw on the hatch (when doing that have some one hold the hatch). After that all you do is twist the strut counter clock wise and should come off. Note supposing they are the same size screw when you take off the strut you should be able to use the new one and screw it back in. After putting in the new one plug it back into the ball screw on the hatch and clip it in.
Beware of the clip haha that thing is a _____ to work with.
Old May 10, 2008 | 04:30 PM
STNC's Avatar
Roger
Old May 13, 2008 | 12:52 AM
jetlounge's Avatar
you don't need 2 people...you do 1 at a time carefully.
i changed mine out myself, no problem.
Old May 13, 2008 | 12:54 AM
fujita_TC's Avatar
why do you need it....a bench spoiler?
Old May 13, 2008 | 12:57 AM
Eltaco's Avatar
Thinking he is going for a "burlwood" spoiler.
I agree with the 1 at a time install. I put a new grill on my Ram that added about 10lbs to the weight of the hood and it wouldn't stay open. Got some HD struts and installed 1 at a time.
i'm going to guess maybe something audio related, trunk mounted speakers or subs.
Old May 13, 2008 | 12:59 AM
fujita_TC's Avatar
yea sounds more like it...or tvs..
Old May 13, 2008 | 01:21 AM
SW_T-SEE's Avatar
probably a bookshelf spoiler
Old May 13, 2008 | 02:47 AM
STNC's Avatar
lights
Old May 13, 2008 | 04:52 AM
Dr_Isotope's Avatar
I needed new hatch struts after I put the Viniati CF spoiler on... the stock ones would just hold the hatch open-- and the spoiler weighs maybe 4lbs.
Easy swap.
Old May 13, 2008 | 05:03 AM
STNC's Avatar
well i'll need it for the viniati spoiler and 6 pounds
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
swtbabiboi4u
Oct 13, 2003 04:38 PM
swtbabiboi4u
Oct 10, 2003 01:40 AM
