Ingalls Engine Damper + Front Strut bar?
Old May 16, 2008 | 10:28 PM
tCmaniak's Avatar
Default Ingalls Engine Damper + Front Strut bar?
Can both go on? or is it a one or the other deal?
Old May 16, 2008 | 10:39 PM
draxcaliber's Avatar
they can usually both be installed, depending on the layout of the strut bar, like the dc sports one versus the hotchkis and trd ones.
but usually the engine damper goes under the strut bar.
Old May 16, 2008 | 10:43 PM
tCmaniak's Avatar
I Just bought the greddy strut bar. Are you sure the bar goes over the ETD? Wouldnt that throw the way the bar sits off center being that it bolts up to both sides? To where the ETD only bolts to one?
Old May 16, 2008 | 10:59 PM
olo_olo's Avatar
yes both can go together!!!! i have both on.
Old May 16, 2008 | 11:52 PM
yes, because the ETD attaches to the strut tower via bracket that would fit under the strut tower brace.
Old May 17, 2008 | 12:28 AM
tCmaniak's Avatar
ok and the strut brace being "off center" like that...is that goign to affect performance? Would it be better to remove the ETD and put the strut bar UNDER it so the bar itself is balanced and then throw the ETD over the bar?
Old May 17, 2008 | 12:44 AM
i realy can't imagine the ETD fitting over a strut tower brace.
btw, on our cars a strut towr brace does nothing. and even so, all it is supposed to do is add strutural rigidity under hard cornering to resist chasis flex.
Old May 17, 2008 | 12:50 AM
tCmaniak's Avatar
wait what do u mean it does nothing on our car? Bolting it up to the chassis gives it a stiffer setup hence better cornering correct?
Old May 17, 2008 | 01:08 AM
amp0804's Avatar
Yeah probably at around 145 MPH
Old May 17, 2008 | 01:33 AM
tCmaniak's Avatar
hmmm
Old May 17, 2008 | 02:12 AM
because our strut towers are so close to the fire wall, they really don't provide any addtional rigidity.
Old May 17, 2008 | 03:07 AM
tCmaniak's Avatar
god damn...there are so many things withur car that set it back from a competative advantage. this blows... good thing i love the tC cuz man...
Old May 17, 2008 | 03:16 AM
it isn't a disadvantage, it just means that the strut tower brace is unnecessary. so if you don't need one, who cares, means less weight, which is good.
Old May 17, 2008 | 03:27 AM
tCmaniak's Avatar
well might as well throw mine on now.... already bought it...
Old May 17, 2008 | 03:44 PM
tCmaniak's Avatar
besides what I mean by disadvantage is I dont htink its because we dont need one... its just because the mount is too damn close to the firewall. I am sure if somehow it could be mounted further away it would help just like any other.
Old May 17, 2008 | 04:53 PM
HaYnSktC's Avatar
both will work together just put some washers on the other side to make it even
Old May 17, 2008 | 05:07 PM
tCmaniak's Avatar
ah very smart thank you.
Old Jul 2, 2008 | 04:42 PM
rbcutlery's Avatar
will it work with a tanabe sustec strut bar
kleecker
Jan 9, 2015 02:26 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
tC6M
Dec 1, 2014 02:06 PM
anarvan
Oct 31, 2003 01:14 PM
randode
Oct 27, 2003 02:37 AM
