Brakes 2006 xb has clunking sound when first put into dirve
Old May 19, 2008 | 06:11 AM
RBbox's Avatar
Default Brakes 2006 xb has clunking sound when first put into dirve
I just brought my b in for the last free oil change and asked about a noise I get when my car is cold I first shift into drive from park and as I relase the brake pedal I hear a clunking noising. It goes away once you start driving but it is something I just started noticing, The Scion dealer says it is the rotors are a little loose when you first start then self center themselves. I don't know about this and it sounds fishy. has anyone else run ito this noise. Anyone else have this?
Auto trans
2006 xb
12,690 miles
Old May 19, 2008 | 02:26 PM
D_M_A_N's Avatar
My brakes do that... they've always done that tho'
Its the same on my camry
Old May 19, 2008 | 02:32 PM
burstaneurysm's Avatar
It's normal.
Old May 19, 2008 | 04:19 PM
DVSAZN's Avatar
just cold rotors & pads biting... normal...
Old May 20, 2008 | 01:48 AM
Sciond's Avatar
yep^
Old May 20, 2008 | 03:10 PM
JSosa's Avatar
I change my pads and it this happens to me when i don't PERFECTLY center the rotor on the hub. Its really difficult to get it perfectly centered but i go through the trouble. Since you don't do your own brake, mechanics wont go the extra mile to make it fit dead-on, so don't worry nothing is going to happen, you just get a slight clunk noise. It happens to manual transmission too, usually when your moving forward, stop, then reverse and when you first touch the brake you get the clunk.
Its all about the rotor moving slightly with the pressure of the pad.
Old May 20, 2008 | 08:00 PM
Black_Sheep_xB's Avatar
also.. pads are designed to be a little smaller than the bracket they are in, so when heat expansion takes place the
pad doesnt lock or get stuck in the bracket. So, when cold and all the metal shrinks down, you now have pad play in the
bracket, the pad is shifting front to back or back to front... then... "clunk"
Old May 20, 2008 | 09:29 PM
D_M_A_N's Avatar
its the pads on mine. Not the rotors.
It does it as I back out of the driveway every morning.
Old May 20, 2008 | 09:34 PM
swire2's Avatar
I have a manual and I have some kind of clunking noise. I get the noise when I am accelerating in first or second gears. It is most noticeable when I just start to drive. Would this be the same thing your are talking about or could mind be something different?
Old Jul 8, 2008 | 03:31 AM
TheSaint77's Avatar
Moderator
Moderator
i kinda get this too, i also get a creaking sound when i first turn the wheels first thing in the AM. Sound familiar to anyone?
Old Jul 8, 2008 | 03:43 AM
D_M_A_N's Avatar
If you're moving, the creaking is probably suspension.
Mine does that too. I'm running stock suspension so far.
Old Jul 8, 2008 | 01:20 PM
TheSaint77's Avatar
Moderator
Moderator
Yeah, my suspension is stock as well. Have you had anyone look at it?
Old Nov 5, 2008 | 07:28 PM
TheSaint77's Avatar
Moderator
Moderator
bump
Old Nov 6, 2008 | 04:36 AM
D_M_A_N's Avatar
no its not a big deal to me.
moving parts will make noise.
evolving_machine
Oct 21, 2023 01:16 PM
Squishface
Sep 15, 2015 06:51 AM
corbmonster
Jan 24, 2015 05:22 PM
toyotaisme
Jan 10, 2015 10:24 PM
Kiwibox
Dec 15, 2014 09:46 PM
