WOT/Boost issues
Old May 27, 2008 | 06:08 PM
SoFloTC's Avatar
Default WOT/Boost issues
hey guys so i have the dezod s1 kit with the AEM fic and lately after i was tuned like 4 weeks ago theres been some issues..
the cruising is fine no problems but if i get on it, it wont reach my 6 lbs easily which im set at.. sometimes the AFR (digital AEM gauge) goes really high and then to --- and my boost spiked to 7 once.. when i gas it heavy in throttle or WOT that occurs and then my car doesnt go anywhere at all and all i hear is pop pop pop pop seems like its slowing actually idk whats going on
Old May 27, 2008 | 06:17 PM
tC_2NeR's Avatar
Does it smell like a go-cart when ur car does that?
----It could be running too rich at wot.
Does the pop pop happen when bouncing off the rev limiter and during shifting?
Maybe possible exhaust mani leak thats preventing u from hittin full boost.
Old May 27, 2008 | 06:18 PM
SoFloTC's Avatar
i have an auto so it shouldnt be bouncing off the rev limiter.. i am running rich but why wouldnt it have been doing it before and just lately? i kno i have a small leak in the exhaust mani but why wud my afr go ---
Old May 27, 2008 | 06:19 PM
B_Real45's Avatar
First you should fix your exhaust leak in your manifold. That will slow your spool big time.
Old May 27, 2008 | 06:37 PM
tC_2NeR's Avatar
so wait,
what i got fro your OP is that it happened right after u were tuned right?
Old May 27, 2008 | 07:07 PM
enjoithis's Avatar
im having alot of trouble with my F/IC... are you running a boost controller?
Old May 27, 2008 | 11:19 PM
SoFloTC's Avatar
no boost controller.. no started happening like 3 weeks after tune.
Old May 28, 2008 | 01:23 AM
paul_dezod's Avatar
Scionetics
KAD
The POPing sounds like detonation. I would be leary of that happening regularly.
The boost leak, if bad enough could cause the flux in AFRs (dependng on where it is)
You have a 3" exhaust right?
Old May 28, 2008 | 01:25 AM
SoFloTC's Avatar
correct 3" all the way except the dpipe/spipe
Old May 28, 2008 | 01:38 AM
paul_dezod's Avatar
Scionetics
KAD
Did it ALWAYS spike since you have had the 3" with the turbo?
Old May 28, 2008 | 01:42 AM
SoFloTC's Avatar
nope just lately .. it used to run fine.. and its not all the time this is happening either.. just sometimes when i take a ride and go WOT its like pop pop pop boost is weird and the AFR goes --- and my car feels really heavy
Old May 28, 2008 | 03:17 AM
silverstreaktc's Avatar
check for leaks
Old May 28, 2008 | 05:24 AM
SoFloTC's Avatar
so i got in the car 2nite and it was hitting boost fine at WOT and everything it started going but then the a/f went high then to --- and the car seemed like it wasnt going anywhere after that
Old May 28, 2008 | 12:46 PM
B_Real45's Avatar
Sounds like limp mode on an automatic..
Old May 28, 2008 | 01:32 PM
paul_dezod's Avatar
Scionetics
KAD
Sounds tuning related. Sounds like it's leaning out. Hesitation like that is usually from a lean AFR
Old May 28, 2008 | 02:40 PM
enjoithis's Avatar
do manuals have a limp mode?
Old May 28, 2008 | 03:22 PM
yellowxhoodie's Avatar
yea, its called first gear. lmao
Old May 28, 2008 | 03:48 PM
krazylowgsx's Avatar
take a trip back to the dyno... one pull and you'll know what the problems is!
Old May 28, 2008 | 04:07 PM
enjoithis's Avatar
im not going back to the guy who tuned me.... waste of time and money!
Old May 28, 2008 | 05:02 PM
etsnet's Avatar
When the AFR gauge goes to -- are you sure your foot isn't coming off the gas? I know to some that might seem like a no brainer but you never know.
