AEM Wideband problems any suggestions.
Ok I got a Wideband AEM Gauge for free that was supposed to be working.I installed it and it stays at 14.7 constantly.I couldn't find anything on this site so i searched the web.Seems to be a common problem but couldn't find any answers.Is there a way to reset it?I found the directions for it online but wasn't any help.It powers up goes through a test sequence and then stays at 14.7 any help is welcome.Thanks.
Sensor may be dead. A very common problem for AEM units. You can try pinning out the connections to make sure you are powering up the sensor and it is giving a signal. If so it is a continuity problem.
Sensor issue from the sounds of it. 14.7 is the default setting the screen reads when just power is given to the gauge regardless of weather or not the sensor is attached. Make sure your little clip connector is connected to the sensor, make sure your little clips on the back of the sensor is also in place as well.
I have not had any issues with the AEM widebands out of the box. They are actually pretty good.
hampton1100
Jan 2, 2015 08:13 PM
