What wire goes from the f/ic to aem uego?
Old May 30, 2008 | 07:45 PM
08superwhite's Avatar
Default What wire goes from the f/ic to aem uego?
i've searched all over the aempower forums and I can't find which wire goes from the f/ic to the uego for logging. i know it is the white wire on the uego but i don't know which one on the f/ic
Old May 31, 2008 | 08:17 AM
BrownDogg's Avatar
bump for an answer! I would like to know the same thing. Do you know what wire it is on the f/ic... well what the wire is supposed to do? I have a pin out of the f/ic that i can look at?
Old Jun 2, 2008 | 06:13 PM
apparently i have found out that if you call aem they will send you are wire that clips into the harness on the f/ic. can someone confirm this?
Old Jun 2, 2008 | 07:15 PM
aen's Avatar
aen
white wire to number 18 pin..
try 18 and 17, mine said it was number 17, but it was actually 18.
Old Jun 2, 2008 | 07:19 PM
there is no wire in pin 17 and 18 on my pnp harness
Old Jun 2, 2008 | 07:46 PM
aen's Avatar
aen
you need molex connectors, they send them to you
http://forum.aempower.com/forum/inde...c,20726.0.html
its all in there buddy.
Old Jun 2, 2008 | 08:19 PM
ok, great, thanks alot
Old Jun 2, 2008 | 08:46 PM
enjoithis's Avatar
Theres a wire thats not being used on the harness, the 12v switch (unless u used it) - i pulled that wire out and put it in the pin for the UEGO - worked flawlessly (have fun calibrating it - the mauals values are not very accurate)
Zman
Apr 10, 2015 08:04 PM
mav261
Mar 24, 2015 01:19 AM
mav261
Feb 11, 2015 02:43 AM
