Seat belt problem
Old May 31, 2008 | 04:43 AM
drjohnson36's Avatar
Default Seat belt problem
Whenever I start my car facing up a hill, even just a tiny incline, the seat belt is locked, nearly 99% of the time. This leads to me driving a block or two because I'm not able to put the belt on. For some reason it remains locked until I get to level ground, and even after I get to level ground it still takes a minute. Someone wanna tell me if this has happened to them? If its normal? If its not, then how do I fix it?
Old May 31, 2008 | 05:06 AM
O5_TRD_tC's Avatar
it locks on me if i move forward too, i guess its normal?
Old May 31, 2008 | 06:22 AM
Yeah if I'm moving forward it'll lock obviously, but I'm talking about having just started the car up, before I even put the belt on.
Old May 31, 2008 | 06:23 AM
tC2_thumper's Avatar
this might sound crazy, but put seatbelt on THEN start it?
Old May 31, 2008 | 06:24 AM
richyrich's Avatar
WTF!
Old May 31, 2008 | 06:25 AM
FTW!
Old Jun 1, 2008 | 05:20 PM
It's still locked, even if the car's off.
Old Jun 2, 2008 | 05:50 AM
aen's Avatar
aen
what the hell?
ive never experienced ANYTHING like this before
Old Jun 2, 2008 | 09:32 PM
King_4_A_Day's Avatar
Yea sorry dude but you maybe the only person with this problem. Good luck figuring it out tho
Old Jun 2, 2008 | 10:51 PM
Alright thanks I'll check other forums
Old Jun 3, 2008 | 09:13 PM
Devedander's Avatar
Sounds to me like the brackets that grab your seatbelt are a little too sensitive... probably need to take it to someone to have them adjusted or looked at...
Old Jun 3, 2008 | 09:16 PM
suatns's Avatar
arnt thoes brackets under the seats?
Old Jun 3, 2008 | 09:22 PM
goingcarcrazy's Avatar
Don't quote me on this (rather, quote Richard Hammond since he's the one I learned this from via a TV show he hosts on the Science Channel). There is a heavy ball that sits inside a larger hemispherical cup sort of thing and whenever that ball moves in a direction, it also travels up the side of this "cup" making it hit a lever sort of thing, jamming it into a fixed gear, hence, locking the seatbelt. So with this in mind it sounds like the lever is a smidge weak. Might be something to look into fixing, and although I've never done it, it seems like a somewhat easy fix if you have small hands.
Old Jun 3, 2008 | 09:33 PM
CarbonXe's Avatar
They're in the rear quarter panel, right under the B-Pillar.
Old Jun 4, 2008 | 12:31 AM
Another thing I've noticed is that the seat belt will lock whenever the accelerator is pressed, no matter how lightly, even if it doesn't result in a change of speed.
Old Jun 4, 2008 | 02:21 AM
sciontc_mich's Avatar
^^^ definitely has a problem with the seatbelt mechanism. Nothing you're doing. It's defective, dealer should replace it, just have to take the side panel off to get to the mechanism.
stillcole
Scion tC 2G ICE & Interior
Jun 14, 2015 09:19 PM
carid
Jan 22, 2015 12:49 PM
toyotaisme
Jan 10, 2015 10:24 PM
cid_mcdp
Jan 5, 2015 02:45 PM
xvolcomx88
Nov 27, 2003 09:23 AM
