VRD fog light wiring confusion...UPDATE! VRD's are on!
Old Jun 6, 2008 | 08:23 AM
B_tC's Avatar
Default VRD fog light wiring confusion...UPDATE! VRD's are on!
Ok, so I got my Fogs in from Ebay. Opened it, and found some wires that did not make sense to me. I'm no electrical expert and i have never done splicing before, but I think it's common sense to know what plugs in what. It's the whole switch part i dont get. where does the rest lead to? I can't find anything that leads it to the foglights. Am I missing anything? SL, much help appreciated!
So here is what i got in the package.
____________________________________________________
UPDATE:
Pix of my friend and i with his mk1 rabbit. old school! hella sick.
& Here's a Video of my VRD's in action!
Old Jun 6, 2008 | 08:45 AM
mrcoolgarcia's Avatar
the wiring you have is a partiall yet coplete set
they are using your car that has a partial harness already in it pre wire
the swich by the left side of the stering is simple to conect just remove the cover for the fuse box and look aroung for a plug thata ussualy wraped around with blk tape but its there then hide the relay so its out the way ,make sure you put the fuse provided nt the fuse box in the engine compartment
now the front fog light remove the covers and place the fog lights , remove the under covers of the car (its easy if the car is lifted on a hoist or lifted with a floor jack and crawl under ) look on the driver side of the car but behind the bumper and fender there is a hiden plug there for the fogs and there is a ground wire to tap in to
you could try to go your local toyot dealer and ask them for the instructions for the factory fog light its the same just that factory mounts on you front lower gril its very simple install
if you need pics i can email you some or i can post some if you like
Old Jun 6, 2008 | 08:48 AM
B_tC's Avatar
oh yes please do email those pictures for me! I'd greatly appreciate it!
Old Jun 6, 2008 | 09:26 AM
O5_TRD_tC's Avatar
u got everything,
look up the toyota instructions for the OEM fogs. They are identical.
Old Jun 6, 2008 | 09:42 AM
B_tC's Avatar
ok, i think i get the idea now. it is identical to OEM fog lights, and there is a grounding mount on the drivers side. and the harness with the black tape connects to the harness attached with the fog light switch. so theres nothing connected to the battery?
Old Jun 6, 2008 | 09:55 AM
O5_TRD_tC's Avatar
yes there is a ground point on the drivers side
Old Jun 7, 2008 | 01:24 AM
B_tC's Avatar
one more thing guys, when connecting the fog lights,
is it black to red, and white to white? or vise versa?
Old Jun 7, 2008 | 05:25 PM
Atr3yu's Avatar
Use the SEARCH function................................................There r a ton of DIY on fog installs
Old Jun 7, 2008 | 06:22 PM
imsonofagun's Avatar
start at step 4. It's for the OEM fogs, but connects the same.
http://www.trdsparks.com/install/PT413-21050inst.pdf
Old Jun 7, 2008 | 07:02 PM
tcCALI's Avatar
silence.
Old Jun 8, 2008 | 06:05 AM
B_tC's Avatar
eh i got them to work. but now, one of them are starting to fog up. ill post up some pix later on.
Old Jun 8, 2008 | 06:12 AM
FLINTstone's Avatar
silence.
there are also hundreds of threads identical to this one with people asking to be spoonfed information instead of searching.
Old Jun 8, 2008 | 06:26 AM
B_tC's Avatar
i did search, and its not retarded. i got the info needed. got them to work. that's all that matters. let's move a long.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
LzeroKI
Scion tC 1G Aero & Exterior
Feb 10, 2015 07:28 PM
nastytc
Jan 27, 2015 03:50 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
tc_Jake
Dec 31, 2014 01:45 AM
