Boost "issues" on TRD SC
Old Jun 7, 2008 | 04:07 PM
Buck's Avatar
Default Boost "issues" on TRD SC
Well, hello. Currently I am just running on my 9.5lb pulley again, but on my AEM boost gauge the highest I seem to be seeing is like 7.5lb. Out of boost, it reads something like 20-24 vacuum, for what thats worth. I am trying to figure out if it is my BPV, the gauge, or just normal. I had to go back to the 9.5 from a 10.5 because I am waiting for a tune.
Right now my car has:
TRD Reflash (F/IC is unhooked)
full exhaust (header---Back)
NST 9.5lb Pulley
AEM Boost Gauge
I think thats all that would effect this.
I know we get like 5 of these a week, but I am looking for ay input, thanks!
Old Jun 7, 2008 | 04:10 PM
chicotunner07's Avatar
running the 9.5lbs pulley wont do any good if ur still running the stock BPV, you need to upgrade to a Forge or a stiffer Bosch if u wanna keep it the same brand as the factory
all the extra boost ur SC is making is being leaked out through the stock BPV
Old Jun 7, 2008 | 04:14 PM
Buck's Avatar
Shoot, I forgot to mention that. I have a forge 007 BPV
Old Jun 7, 2008 | 04:15 PM
lol, well might be something else then, by the way, what was the boost reading before u swapped the pulley?
Old Jun 7, 2008 | 04:25 PM
Buck's Avatar
yeah... I didnt have the gauge on it before. I really didnt plan this one out. It is only temporary with the 9.5 for a couple days, but still, I would like to get it worked out for that time. Its going in next week for the Water/meth, injectors, and the 10.5 tune.
Thanks for the input though, at least someone chipped in haha..
CSOCSO's Avatar
change the spring to stiffer..
Old Jun 7, 2008 | 04:28 PM
Buck's Avatar
Yeah, im waiting for the pring kit to come in... I ordered it from Forge a couple days ago, and it should have been here yesterday. Hmm, thanks for the reminder. What do people usually use in them?
Old Jun 7, 2008 | 05:03 PM
05-RS1's Avatar
gauge might be inaccurate too. check vacuum lines and make sure they're all zip-tied. when you tune, tune it off a MAP sensor instead of the MAF and you'll know definitely how much boost you're at.
Old Jun 10, 2008 | 11:48 PM
Buck's Avatar
OK, so I am still waiting for my spring kit for the 007... I ordered it a week ago, and it is pretty irritating that it hasnt come in or anything yet...
I would hope the gauge would be fairly accurate, I haven't heard complaints about the AEM gauges. All VAC lines are zip tied and tight, and I mad sure it wasn't getting pinched where i goes through the firewall.
Old Jun 11, 2008 | 01:06 AM
2_much_tc's Avatar
where did you tap the vac line for the boost gauge? the farther it is from the throttle body, the more inaccurate it gets...
Old Jun 11, 2008 | 01:04 PM
BLUEMEANIE's Avatar
Team Hamster
tap the gauge as close to the TB as you can and use the red spring with 3 shims. I was having the same problem but no I'm hitting 10lbs regularly.
Old Jun 13, 2008 | 09:46 PM
Buck's Avatar
Ok, well I actually found my issue... the bel was slipping pretty bad. I have my 10.5 back on now with the right belt for it, and I am definitely working properly now. I actually have the blue spring with 3 shims now. boost starts ~2500 and hits 10 on my gauge just before redline.
Thanks for the help!
Old Jun 15, 2008 | 04:30 PM
CSOCSO's Avatar
nice.. how much hp??
Old Jun 15, 2008 | 04:41 PM
Buck's Avatar
Eleventybillion...
honestly, I dont know. I am going to get in touch with Dezod this week, and hopefully get the AEM F/iC tuned then Ill put it on a dyno. I think I am going to hold off on the water injection for the time being, I dont think its worth the effort (the kit is in my garage)
Old Jun 15, 2008 | 05:03 PM
crush02342002's Avatar
do it do it do it....lol
Old Jun 17, 2008 | 12:34 AM
TRDChargedtC's Avatar
im having problems with my stock boost too.. its not but building 1 or 2 pounds til 5k rpms and then it gradually goes up to 7 at redline.. is this normal?
Old Jun 17, 2008 | 12:48 AM
Buck's Avatar
I know with the 9.5 it didnt build until 3k, and with the 10.5 I make 2lbs at 2500 RPM. I never had a gauge on it with the stock pulley.
Old Jun 17, 2008 | 02:27 AM
well i know its really slow becuase i only ran a 15.7 in a 1/4 and im not sure whats wrong with it....
Old Jun 17, 2008 | 03:46 AM
TCFROEZEL's Avatar
Where did u get your 10.5 PSI pulley ?
Old Jun 17, 2008 | 04:55 AM
1_kLEan_tC's Avatar
NST makes the special order!
