Injectors
Old Jun 11, 2008 | 03:25 PM
lonerxB's Avatar
Default Injectors
Hi everyone,
I don't own an (or a) xB, but I have a Toyota which has a 1NZ-FE engine. Right now, i'm doing a turbo setup with low compression CP pistons (9.5:1 CR) and crower rods.
I'm planning to use a Garrett GT2860R blower with a front mount intercooler.
I have pretty much everything except the injectors. I'm read thru and found that some guy used a ford contour svt injector and they were a direct fit. however, looking at the pictures below, i'm kinda skeptical about the inlet fitting onto the stock fuel rail, coz the stock injector's inlet seems much thinner than the ford's. Anyone can shed some light?
Stock Injector:
Ford Contour SVT Injector:
Also, will this bigger (410cc, for a Ford Cobra) injector fit? :
Old Jun 11, 2008 | 06:08 PM
symiansix's Avatar
Default injectors...
i dont know how much boost you plan on pushing into your 1nz but i run 8 psi in mine and i used a set of Tc injectors and a perrin fuel rail and have had alot of luck. The Tc injector pushes 380cc i beleive. I dont beleive either way that those ford cobra injectors are going to fit because the fuel rail side requires a donut gasket while the cobra one looks to be an oring.
Old Jun 11, 2008 | 06:21 PM
lonerxB's Avatar
Default Re: injectors...
I plan to push in probably 16 psi of boost for a start... hehe
are the Tc injectors a direct fit??
do u have a pic of the Tc injectors? Thanks for replying man!
Old Jun 12, 2008 | 01:49 AM
itlstl13's Avatar
do u plan on building up the motor to support 16 psi??... cuz if not it wont be running at the 16 for awhile
Old Jun 12, 2008 | 01:57 AM
lonerxB's Avatar
yeah! hope everything works out fine for me.
so, i suppose the injectors won't fit eh. Any other solution? I bought come injectors from RC, and they didn't fit coz the fat body was hitting the head.
Old Jun 12, 2008 | 01:39 PM
JSosa's Avatar
I have a friend of mine thats selling RC engineering 550cc injectors. They were used on a 1ZZ-FE, but fit perfectly on a 1NZ-FE.
Old Jun 12, 2008 | 02:55 PM
vettereddie's Avatar
I can put up tC injector pics later. They are a direct fit. Keep in mind with the Ford ones as well that you will need to wire them up, and I doubt the electrical connectors will fit as is. Dezod gets theirs from Deutchworks I believe if you need to go larger than tC stock ones.
Old Jun 12, 2008 | 03:30 PM
lonerxB's Avatar
do u have a part number for the RC Injectors??
Old Jun 12, 2008 | 08:53 PM
JSosa's Avatar
no, sorry about that. If your truly interested let me know and i can make a few phone calls.
Old Sep 17, 2008 | 02:13 PM
captdownshift's Avatar
Strictly Scionized
send tc injectors to scott @ usrallyteam and he can hog them out for you (with lasers or some crasy ish) anyways they do a great job, just let'em know hoe much flow you'll want and he'll let you know what he can do, or what he can get you for the application.
Old Sep 17, 2008 | 03:16 PM
paul_dezod's Avatar
Scionetics
KAD
Just use 2AZFE injectors. Proven to fit and stocks flow 320cc
SloTC1
Aug 16, 2018 02:45 PM
MeDizzy
Oct 8, 2015 03:31 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
brett561tc
Sep 15, 2015 06:33 AM
k1114
Mar 6, 2015 03:43 PM
