How to make my A/C colder?
Old Jun 17, 2008 | 01:11 AM
fatboitan's Avatar
Default How to make my A/C colder?
It seem my A/C has gotten weaker since i bought my 07 tC. The A/C has not been cooling the inside of my car as fast.
My bros Civic cools his down extremely fast and i was wondering what can I do to my A/C to make it colder and blow air out harder?
____
Old Jun 17, 2008 | 02:19 AM
kidwolf908's Avatar
Well I doubt you need a freon recharge, but it's possible if your cooling system has a leak. You should take it to the dealership to be checked out if you really think there's a problem. There's really no DIY solution to make your AC colder...put ice cubes in ziploc bags on your lap... that will chill you and your nuts down pretty quick.
Old Jun 17, 2008 | 02:49 AM
sciontc_mich's Avatar
actually it's possible it wasn't charged up to the max level from the factory. that's probably what it is. Others on here have found that to be the case. if it's not blowing cold, then the refridgerant isn't up to the correct level.
Old Jun 17, 2008 | 03:12 AM
Rydrdg's Avatar
put dry ice around ac vent
Old Jun 17, 2008 | 03:25 AM
Need4Bass05's Avatar
Mine is the same way. It just doesnt seem to cool down the car fast enough and even having it on high it seems like you car barely feel it.
fatboitan's Avatar
so would that cost me any money or is it cover under factory warranty? also i have a sound system and avic-d3 installed will that affect my a/c warranty or if there was a chance the install cause the problem?
Old Jun 17, 2008 | 04:02 AM
miniaznkid's Avatar
theres a kit out there which u can do it yourself i saw it at pepboys
Old Jun 17, 2008 | 04:08 AM
ScionJim23's Avatar
make sure you actually hit your A/C button on. not just turn the **** to cold. lol. so many people have done this and just cool air come out. anyways, maybe you have a leak. mines an 06 and my a/c is damn cold still. even when its almost 100 out.
Old Jun 17, 2008 | 04:25 AM
fatboitan's Avatar
a/c button is on its not that my ac doesnt get cold it take it a while to get to the temp. Like today after work when i got out at 4:30 it took my car nearly 10min to cool my inside
Old Jun 17, 2008 | 06:14 AM
don't do it yourself, it's definitely covered under warranty. Yeah I'm telling ya, it definitely sounds like there is either too much or too little r-134a (refrigerant) in the system. If there is too much or too little, has the same effect, very slow to cool.
First the dealer will stick a thermometer in the vents to see what temp it's blowing out, then they will see it's too warm, they'll evacuate the refrigerant from the system, and see how much refrigerant comes out, and then ask them to put the max amount into the system. which on ours I think is 1.0lb. You'll see a difference right away.
It doesn't take mine 10 minutes to get cold air. I get very cold air from the vents within about 5 seconds! just get to the dealer and let them check it out, if they're any good, they'll find it and fix it quickly.
Old Jun 17, 2008 | 11:35 AM
djpeaty's Avatar
I noticed that if I also press the button right below the A/C button is gets colder faster.
It is the recirculate button with the car and the arrow.
As you are cooling the air that is already cold and not hot air from outside.
Good Luck!
Old Jun 17, 2008 | 02:18 PM
fatboitan's Avatar
okay ima take it to the dealer also does my sound system in anyway affect that a/c? like electric wise?
Old Jun 17, 2008 | 04:55 PM
unless the aftermarket system has tapped the power to the hvac controls (lcd panel). I don't see how the sound system could affect the a/c's performance.
Old Jun 17, 2008 | 04:58 PM
justin6969's Avatar
1 question is ur windows tinted? if not that will help out alot
Old Jun 17, 2008 | 05:59 PM
stCx86's Avatar
Default air conditioning
I had this same problem back when i first got my car in 2005. I took it to the dealer and they said it was blowing at optimal level...=/ till this day it's still not COLD enough for me. Now that summer is coming around, I really want SUPER COLD AC!
Old Jun 17, 2008 | 11:14 PM
Mika's Avatar
Default Re: air conditioning
My '06 tC is the same. One time going to Scion Night with some friends, rolling down the window while driving worked better than the a/c. About the only thing cold in the car was my hand/forearm when the a/c was on. The dealership told me that it was at the optimal level too, when I took it in soon afterwards.
Old Jun 18, 2008 | 12:48 AM
^^^ I think that the dealer telling you "it's fine" is just a lie. I'd make them evacuate the system and prove to you how much refrigerant came out of the system. Then when it's not the correct amount, then you can smile and say "Told ya so!" Do these people just come into work and make up lies just so they can do nothing all day and still be paid?
if it's cooler by rolling your windows down, it's OBVIOUS there's something wrong with the a/c system. Maybe try another dealer, someone who actually LISTENS to your problem?
Old Jun 18, 2008 | 02:03 AM
fatboitan's Avatar
well i got back and they said it was fine. They left my car in the sun for 30min and then cool it down to 42 degree in 3min time. I told them to pump 1lb of refrigerant but he said that if you pump too much then it'll mess up the ac since he did it to his own car (not a tc) and it took longer for his ac to cool it
Old Jun 18, 2008 | 03:08 AM
justin6969's Avatar
lol should told him 2 evac & recharge it
Old Jun 18, 2008 | 03:22 AM
Mika's Avatar
I actually went to more than one dealership and they all said that. Maybe I just had too many people in the car (4 live bodies) giving off heat?
