Supercharger Tune (not starting)
Old Jun 23, 2008 | 03:37 AM
m6ar2cel6oTC's Avatar
Default Supercharger Tune (not starting)
ok heres the deal. i got my car tuned couple days ago with the emanage blue and the car ran perfect made 251 whp and 220lbs. now my problem is i drove the car all day perfect then the next day when i get into my car in the morning it wouldnt start it would try to and i press the accelerator and it will just sputter and then die. then i unplugged the emanage and plugged up everything back to stock and the car started right up. then drove it around came back to my house plugged in the emanage back up and the car started just fine. so pretty much when the car hasnt been started for hours or being started for the first time in the morning it wont start. but after when the car is hot or warmed up the car starts just fine with the emanage. and i dont wanna always bplug my stock ecu up then crank it drive it around then plug back the emanage. does anyone know whats the cause of this? i was told it might be my plugs that need a smaller gap or something like that? could that be it? right now i have the stock trd plugs in. thanks!
my mods are 9.5 pulley, zpi exhuast, megan header and s pipe, hks cold air intake and emanage. by the way i have the 12 psi pulley but havent put it on yet cause my tensoiner bolt broke lol.
Old Jun 23, 2008 | 03:40 AM
1_kLEan_tC's Avatar
No clue!
Old Jun 23, 2008 | 04:19 AM
2_much_tc's Avatar
good luck bro.... might be something simple, but who knows...
Old Jun 23, 2008 | 07:35 AM
i hope it is. thats why i am gonna try the plugs( 2 steps colder ones) they have a smaller gap then the trd ones. i hope it works. cause i am running lean as hell since i got hks cold air and i am running rich as hell if i step on it.
Old Jun 23, 2008 | 01:33 PM
speedy's Avatar
check your e-manage conection, and the chip inside the e-manage
Old Jun 23, 2008 | 01:38 PM
B_Real45's Avatar
I would add a little more fuel at idle. Sounds like it's not getting enough fuel with the emanage at idle.
Old Jun 23, 2008 | 04:06 PM
SMACKyoSELF's Avatar
Uhhh as far as the spark plug gap, they should be gapped at .032' i think. At least the stock and TRD plugs are gapped at .032
Old Jun 23, 2008 | 07:04 PM
i thought the trd gap was bigger like 40 or 44 something like that? but i dunno. i would need more fuel at idle? my car idles perfect at idle with the emanage on. its just having cold start issues with the emanage on. but with the stock ecu its perfect. then i plug the emanage on after the engine is warm and starts right up.
Old Jun 23, 2008 | 07:06 PM
and the emanage is plugged in right caquse i triple checked it and about the chip i never done that. but i dont think it would be that cause when they tuned it, it was all perfect.
Old Jun 23, 2008 | 07:54 PM
05-RS1's Avatar
this happened to me too. check your jumpers. i forget which one but i forgot to set the jumper to 12v and once i made the switch it worked perfectly. also try re-uploading the map onto your emanage.
Old Jun 23, 2008 | 08:38 PM
the jumpers? what that? well i am not in miami no more so i can re-upload the the map..
Old Jun 23, 2008 | 08:59 PM
05-RS1's Avatar
jumper settings inside the emanage. you will actually have to open up the unit to make the changes. check the users manual. install the software on your laptop or computer and ask your tuner to email you your map so you can upload it yourself.
Old Jun 24, 2008 | 05:51 AM
well i dunno about doing that i guess i will let a shop do that lol. but anyone else got any input?
Old Jun 24, 2008 | 06:00 AM
unxpectederror's Avatar
i would seriously try what 05-rs1 says. i had the same issue with my supercharged z24 and that cleared it up as well.
its very very simple to do man. just read the manual it will explain which jumper to switch
Old Jun 24, 2008 | 06:35 AM
05-RS1's Avatar
yeah, i think there's even a diagram in the manual. just get a hex screwdriver and open it up.
and i just saw you're FS thread for the 9.5 pulley, so do you have your 12psi pulley on now?
Old Jun 24, 2008 | 01:00 PM
yuh i got it on now but i can only go to 10 psi cause my belt is slipping cause my tensioner broke. so whatever. hey where can i find the manual? cause i got this emange from a friend.
Old Jun 24, 2008 | 01:01 PM
oh and if i get the support tool will i be able to pop up the map and save it then do the whole jumper thing then put back the map on my own or no?
Old Jun 24, 2008 | 01:06 PM
http://www.greddy.com/img/PHP/products/pdf/1286.pdf
thats what i found on greddy.com. what does that all mean lol.
Old Jun 25, 2008 | 05:12 AM
i got a question also. if i connect my emanage now with the trd injectors will it run bad or what will happened cause that emanage was tuned when i had the 550cc injectors. would it matter? just curious. my spark plugs arrive tomorrow hopefully that works.
Old Jun 25, 2008 | 06:19 AM
05-RS1's Avatar
yes that makes a difference. why'd you take the 550cc's off?
