Speedometer stuck at 0 mph (updated)
Old Jun 29, 2008 | 10:00 PM
JCool's Avatar
Default Speedometer stuck at 0 mph (updated)
Today when I start driving my car and noticed the speedometer need is not moving at all, stuck at 0 mph, (rpm, radio, odometer is fine). I don't know what's wrong, the only thing I noticed is that (when the car is parked, no key) when I open the driver-side door, i heard the clicking sound from the speedometer, and the needle moves a little bit to 20mph and stop...
I hope someone can help my issue..thanks..
Updates: today I notice the fuel and rpm will take a 30 second to move after I turn on the car...
Old Jun 30, 2008 | 03:39 AM
crex149's Avatar
That's a new one. Have you had the dash apart at anytime? Gauge swap or anything like that?
Old Jun 30, 2008 | 07:33 AM
JCool's Avatar
not at all, never take out anything at all...
Old Jun 30, 2008 | 08:44 PM
Bsbox's Avatar
Take it to the dealer but first look up the TSB list and see if anything matches your description of the problem. I've never heard of anything like that but it should be under warranty.
Old Jul 1, 2008 | 08:24 AM
crex149's Avatar
^Sounds like the best plan. That's why I was wondering if you had done anything to the gauges. If not, take it in.
Old Jul 4, 2008 | 05:54 AM
jwaj2002's Avatar
TOCC
I wonder if a relay went bad
Old Aug 5, 2008 | 06:06 PM
Newtmaker's Avatar
Default Re: Speedometer stuck at 0 mph (updated)
Strange! My 05 xB is doing the same thing. It has 67000 miles and it started about 2k miles ago. Sporadically it will work again but lately not very often. The fuel gauge and tach also do the same as far as taking a while to register after it is cranked. The tach is also very prone to sticking at weird rpm's, like 100 rpm idle or 3500 rpm idle.
The dealer wants 395.00 for a new cluster. NOT!!! I ordered a Scan Guage II and will rely on it from now on.
Walt
Old Aug 5, 2008 | 09:45 PM
JCool's Avatar
is scan guage 2 working fine even the thing is not working right..i might get one too...
Old Aug 5, 2008 | 10:45 PM
jct's Avatar
jct
yes it does work fine, my tach acted up a few months ago and i said to my self that aint right so i compaired it to my scan gauge and i was right the SG was dead on and my tach was off...
Old Aug 31, 2008 | 12:51 AM
itsZACyo's Avatar
i have the same problem with my tC. if i lock it and leave it alone for like 3-4 minutes and then unlock it and open my door i hear clicking and grinding noises from the gauge cluster. The dealership
has no idea what's going on and told me to get a new cluster but that's over 700!! still doing research to see if i can get my own used cluster and program the odometer to match my mileage.
___
Old Aug 31, 2008 | 05:18 AM
jwaj2002's Avatar
TOCC
sounds like its some relays
Old Sep 11, 2008 | 06:04 AM
45goon's Avatar
Default cluster
I have the same issue as well, but not with my MPH its with my RPM needle not wanting to move at all. My fuel and temp as well as my MPH needles take about 20 secs before they kick in. I have 62k on my car.
Old Sep 11, 2008 | 06:19 AM
itsZACyo's Avatar
have you taken it in to get looked at? any ideas as to solving the problem yet? let me know what you find out
Old Sep 11, 2008 | 06:35 AM
CDogbert's Avatar
Originally Posted by itsZACyo
the dealership has no idea whats going on and told me to get a new cluster but thats over 700!!
That cracks me up. "We don't know what's causing the problem, but maybe buying expensive replacement parts will fix things."
Old Sep 11, 2008 | 07:08 AM
itsZACyo's Avatar
well keep me posted on what the people you talk to tell you about it and what they suggest doing. just repost here
Old Sep 11, 2008 | 12:59 PM
jwaj2002's Avatar
TOCC
I bet its the ECU
Old Sep 11, 2008 | 04:29 PM
misformartin's Avatar
Hmm... maybe try flashing the ECU? Never know.
____
Old Sep 11, 2008 | 05:00 PM
Beckaz_tC's Avatar
I had this happen with my last vehicle. They said it was when the gauge cluster wasn't lubed properly and now has mal-functioned. They had to get me a new $700+ cluster, free to me under warranty.
Old Sep 11, 2008 | 06:04 PM
45goon's Avatar
Hopefully I am still covered under my warranty. $700 I dont have thats for sure.
Old Sep 11, 2008 | 09:09 PM
itsZACyo's Avatar
you shouldnt be covered under warranty because you're over 3 years or 36,000 miles
