need help on spark plug gap for greddy supercharger
Old Jul 3, 2008 | 10:30 AM
cheXmiXB's Avatar
Default need help on spark plug gap for greddy supercharger
i have a greddy supercharger and im goin to replace my spark plug soon and im going to use ngk iridium 1 step colder. BKR6EIX. i used it before and i think i gapped to .034. i did that gap because i found couple post on using it... but on the manual it suppose to be .031 but since im FI, im not sure what gap i should do...what do you people recommended, i took out the spark plug to check the gap now, 1st is .035, 2nd is .034, 3rd is 0.35, 4th is .035. lmk thanks
Old Jul 11, 2008 | 06:49 AM
SRTSVT's Avatar
.35 sounds pretty good. Going down to 30 seems pretty low, I dont know if you can monitor knock but if you can I would try to keep as large of a gap as possible without detonation.
Old Aug 7, 2008 | 01:26 AM
lazermike's Avatar
Rule of thumb where spark plugs and higher than normal cylinder pressure is concerned. Gap them tighter. I would go for mid 20's, they are going to burn bigger anyways. It makes it much easier for the plug to do its job when the gap is smaller. If someone tells you otheriwse, run away.
BlackKnight
Sep 15, 2015 06:42 AM
kleecker
Jul 11, 2015 09:39 PM
tCSpdRacer
May 2, 2015 03:33 PM
daniinpitt
Apr 4, 2015 08:07 PM
06ScionTc5sp1
18
Dec 21, 2014 07:21 AM
