Main't Req'd Light flashing at me... how do I reset it?
Old Jul 9, 2008 | 05:14 PM
drjohnson36's Avatar
Default Main't Req'd Light flashing at me... how do I reset it?
When I start the car, the Main't Req'd light (NOT the CEL) flashes at me for 10 seconds or so and then turns off.
On my old truck, which I still have a haynes manual for, the Main't Req'd light would activate after a certain amount of fuel was consumed... and the only way to turn it off was to take the car into the dealership for "emissions component maintenance".
My question is, is the tC the same way with the Main't Req'd light, in that it would activate when it needed emissions service, or is it just flashing to remind me I need to change my oil? I change my own oil so I clearly don't reset the computer in any way.
Also if it is for something such as oil or something stupid like that, is there any way to reset the light other than taking out the gauge cluster and soldering off the LED?... cuz that's looking tempting
It's an '07 tC Automatic and just went over 12k miles. Thanks in advance!
Old Jul 9, 2008 | 05:16 PM
ack154's Avatar
It is flashing b/c it has been 4500 miles since your last oil change (or at least since it was reset last). It will stay on solid at 5000 miles since last reset.
It's supposed to be a reminder to get your oil changed and other maintenance.
You should look it up in your manual though... will explain further and how to reset it. Or you could search the forums a bit more.
Old Jul 9, 2008 | 05:17 PM
I don't have a manual... lost it
Old Jul 9, 2008 | 05:24 PM
ack154's Avatar
Ah...
Well in that case... I believe this would be how you do it:
- Turn the key on.
- Make sure your odometer is on the odometer (and not one of the trip displays)
- Turn the key off.
- Hold down the trip reset button.
- Turn the key on.
- Keep holding the reset button until you see "- - - - -"
I believe it will show 00000 first and then they'll count down and when they're gone you should see the - - - - -. Then let go of the trip button.
Old Jul 9, 2008 | 05:27 PM
Thanks! I just found it via search tool too... sorry the Dodge forum I used to come on had the worst search tool in the world (would only find one topic) so I'm not really used to it.
Old Jul 10, 2008 | 12:57 AM
BuddhasTC's Avatar
don't forget to change your oil too
Old Jul 10, 2008 | 01:02 AM
paulky_2000's Avatar
That might help!
Old Jul 10, 2008 | 02:16 AM
I changed it at 10k... it's fine
Old Jul 10, 2008 | 04:14 PM
THansenite's Avatar
Bad idea. You should change it every 5,000 miles or less.
Old Jul 10, 2008 | 04:18 PM
ack154's Avatar
I'm thinking it was changed at 5k and then again at 10k (he's only at 12k right now).
Old Jul 10, 2008 | 04:23 PM
Bingo... well close, first at 2k, switched to synthetic at 5k, changed again at 10k... come on who's REALLY that stupid to do their FIRST change at 10k?
missing_image
Feb 7, 2015 07:18 PM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
paul_dezod
Scion tC 1G Wheel & Tire
Dec 10, 2014 06:46 PM
bruceb25
Nov 23, 2014 04:52 AM
deathcabforme
15
Oct 19, 2003 03:18 AM
