Sunroof Won't Close, About to Storm!!!
Old Jul 16, 2008 | 01:02 AM
Wood's Avatar
Default Sunroof Won't Close, About to Storm!!!
Ok, I reset the battery and freaked out when the passenger window wasn't working and some other stuff going on so I searched and figured out the window reset, but before I reset the window I tried to see if the sunroof/moonroof was working, well it opened to the first stop and wouldn't do anything after that. I've tried holding close and open for 1 sec all the way up to at least 30 sec. I've tried resetting the battery again and starting from square 1. I've checked all the fuses visually and have swapped the sunroof fuse with another one. I'm thinking what the problem is that the sunroof isn't closed all the way and in the instructions for resetting the sunroof in the manual says, make sure the sunroof is closed all the way, then hold the button for at least 2 seconds. So does anyone know of a way to manually close it, I've tried pushing on it a little bit but felt the glass bending.
Old Jul 16, 2008 | 01:03 AM
Wood's Avatar
Oh and did I mention it's about to storm, it's already drizzling.
Old Jul 16, 2008 | 01:12 AM
davedavetC's Avatar
no idea man. try disconnecting the battery again and try again, maybe it froze or somethin...
Old Jul 16, 2008 | 01:14 AM
Wood's Avatar
Appreciate the quick response, I think I might try to disconnect the battery for an hour, I read on another forum question to reset it for one hour to do a full reset.
ack154's Avatar
I would NOT suggest forcing it. But if you had to reset the system and didn't do it properly, the best idea is just to disconnect the battery again and do the reset of the sunroof again.
Old Jul 16, 2008 | 01:19 AM
Wood's Avatar
why can't they put a $5 light under the hood, I paid almost $20,000 and they couldn't throw that in?
Old Jul 16, 2008 | 02:56 AM
kikcaffine's Avatar
Nope, you get nothing.
Old Jul 16, 2008 | 02:59 AM
Wood's Avatar
Update: tried restarting from step one after unplugging the battery for 30 min, went and got something to eat and noticed just the Speedometer wasn't working and the function that turns off the headlights when you open the drivers door after the key has been taken out and also the dome light stays on for about 20 seconds after I shut the door with the car started. I'm planning on taking it to the dealership in the morning but I don't want bugs in my car, there are already the tiny green spiders on it. Oh and by the way the rain never happened, just a lightning storm I guess.
Old Jul 16, 2008 | 03:03 AM
Wood's Avatar
Yeah it's sad my old car which was a 96' had a light under the hood. But it was a ford and that's why I don't have it now because it was a ford.
Old Jul 16, 2008 | 03:08 AM
davedavetC's Avatar
damn your car sounds fuked. whatd you do to it??
Old Jul 16, 2008 | 03:09 AM
kikcaffine's Avatar
I dont think my 08 escape has a lite under the hood. Oh well.
kikcaffine's Avatar
Old Jul 16, 2008 | 03:11 AM
TylerC08's Avatar
Ford put a light underneath the hood for a reason.
Old Jul 16, 2008 | 03:33 AM
ninjaionsobe's Avatar
things to check
window lock
1. ECU–IG fuse
2. S/ROOF fuse
3. AM1 fuse
4. IG1 relay
5. Sliding roof control switch
6. Sliding roof drive gear sub–assy
7. Wire harness
8. Faulty sliding of sliding roof
Old Jul 16, 2008 | 04:01 AM
BlckdOutTC's Avatar
this happens whien i reset my battery, the windows come back just after using them a couple times and so does the suroof but at first u have to hold the buttom
Old Jul 16, 2008 | 05:52 PM
highvoltage1's Avatar
Lucky it didnt rain. Hope ya get it fixed.
Old Jul 16, 2008 | 09:55 PM
toeveryhour's Avatar
did you check the fuses?
Old Jul 17, 2008 | 02:06 AM
Wood's Avatar
Ok so here's the new update, took it to toyota, they have no clue what it is, I keep telling them it has something to do with the ecu or something, but they have to look at other possibilities, I keep hearing. So on to the new problem, battery is not charging, barely would start a minute ago, I got to reading and I think it is one of the fuses, according to another person on SL, so I switched it with another fuse and letting it sit for about 20 min. unplugged. Oh and I forgot to mention the people at the dealership we're asking well why did you disconnect your battery in the first place, I knew what they were trying to do, they were trying to get me to say that I disconnected it installing the Short Ram and try to pull the factory warranty won't cover that BS. But if this doesn't fix it, I have to take it or tow it back to them for round 2. So let's see that's tC 1, Dealership 0.
Old Jul 17, 2008 | 02:16 AM
1.do you still have stock battery
2.do you have sub/amp
3. list ALL your problems with the car
4. list all you mods
Old Jul 17, 2008 | 02:44 AM
Wood's Avatar
List of Problems
1. Battery Not Charging
2. Speedometer Not Working
3. Sunroof doesn't work
4. ABS, Check Engine, Brake Light On - Battery Light Does Not Come On
5. Auto Off Headlights Do Not Work
6. Dome Light waits 30 sec. to shut off after door has been shut with car running
7. Cruise Control Not Working
8. Seatbelt Chime Not Working
9. A/C not blowing cold air
10. Car gets bad gas mileage and can smell gas
List of Mods
1. Short Ram Intake, Everything else is cosmetic or suspension
2. A few custom dents and scratches complements of Pizza Delivery
this is the other question I was referring to https://www.scionlife.com/forums/viewtopic.php?t=221567
tried switching the fuse he talked about that's why I'm thinking the ECU is messed up.
